586,076 active members*
3,874 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Steps per/mach3 config
    May 2006
    954
    Hi I'm not sure if this is the right forum but maybe I will get a decent response here. Running a gecko 203v and PMDX-122 based cnc controller. Everything works fine just configuring the steps per inch so that it works properly. The gecko 203s dont appear to use jumpers, (my BOB does) and I couldn't find anything in the gecko documentation provided that talked about micro stepping. I will post my specs here, possibly some can steer me in the correct direction.
    Using on my machine.. 1/2"-10 Acme Size, 2 Turns/inch, 6’l, Rh Threaded ballscrews/acme screws
    305oz bipolar stepper motors
    Gecko 203vs
    PMDX-122 BOB
    Thanks!
    4000 steps/inch. 400 steps/inch x 10 microsteps.
    May 2006
    954
    Edit..
    4000 steps per works.
  1. Config Mach3
    By rex2 in forum Machines running Mach Software
    Last Post: 01-26-2008, 10:52 PM
  2. SX3 - Mach3 - non standard pin config - no movement...
    By krazatchu in forum Mach Software (ArtSoft software)
    Last Post: 11-24-2007, 05:45 AM
  3. Losing steps with Mach3
    By CMPM in forum Mach Plasma / Laser
    Last Post: 07-20-2007, 04:02 PM
  4. Mach3 Steps per Unit (Belt transmission)
    By vdKroon in forum Mach Software (ArtSoft software)
    Last Post: 02-18-2007, 11:42 PM
  5. G-Rex100 and Mach3 Help on I\O Config
    By cybertek in forum Mach Software (ArtSoft software)
    Last Post: 01-02-2007, 05:39 PM
