586,094 active members*
4,177 visitors online*
    Feb 2008
    Mitsubishi DWC Diskette problem
    Hi! I'm from Argentina and new to the site, so I apologize if the post is not in the correct forum.
    I'm having problems withe the floppy disk of a Mitsubishi DWC-90C, the machine reads the disk OK, I can read or write progams from the controller memory to the disk, I can even format the disk, but I can't read it in my computer. I don't know if there's and issue with the format of the disk, I've tried HD disks and DD disk but nothing seems to work...
    I appriciate your help!
    Greetings from the Patagonia!!
    Juan.-
    Dec 2006
    17
    Hi, I just stumbled upon your post from two years ago, but figured I'd reply anyway in case someone else stumbles across this. The floppy file format is not a standard PC format. I don't know what format it is, sorry. If you wanted to copy the disks, you'd have to do some kind of bit-by-bit copy, but even then, your PC hardware is probably not even compatible. Our 110SZ has some strange 2mb hardware format. The drive is made by Citizen and the cable pinouts don't seem to be standard either. Let us know what you find out. I'm having problems with my Mitsubishi floppy as well.
    Cheers
  1. Dnc problem for Mitsubishi Meldas 520AM
    By koeitool in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-11-2022, 07:12 AM
  2. mitsubishi meldos 310 - dnc problem
    By mostafabagheri in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-05-2019, 06:57 PM
  3. Mitsubishi spindle problem
    By wcopley in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2013, 08:58 PM
  4. Dnc problem for Mitsubishi Meldas 520AM
    By koeitool in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-04-2010, 06:40 PM
  5. HELP! Mitsubishi cnc hobb problem
    By Jay Rad in forum Uncategorised MetalWorking Machines
    Last Post: 03-22-2007, 07:08 AM
