I have a hydraulic motor with the following specs:
Disp. 0.277 Cu-In/Rev.
Torque 50 in-lb. Max
1800 RPM @ 2.16 GPM
5,000 RPM @ 6 GPM Max.
PSI 1,200 Max.
Need help in figuring out how many HP ac motor will I need and what size pump to have that motor spin around 3,500 rpm and have about 40 in-lb max torque.
Would be good to stay with the standard RPM motors 1,700 or 3,400 RPM so I ca direct drive the pump.
