586,068 active members*
4,091 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > TL-1 (program from front or back)
    Sep 2004
    23
    We have a Haas TL-1 lathe in our shop .
    If I make a program in Mastercam , or any other CAM software, which
    way should it be drawn. The way it looks in the machine(the front side of the part), or like our other machines, the back side of the part.
    Thanks WEDDLETON
    Jul 2005
    12177
    Do it the way you do for any other CNC machine where the tools are at the back. For writing programs just treat the TL as a normal CNC machine.
    Really, 'front or back' does not matter, the reference point for the X axis is the spindle centerline; X movement in a negative direction moves toward the spindle centerline. positive moves away. It does not matter whether the tool is in front, behind, above or below.
  1. drawer front inlays
    By mike hide in forum WoodWorking Topics
    Last Post: 01-11-2008, 06:02 PM
  2. End of Program - Front and Center
    By donl517 in forum Fadal
    Last Post: 10-10-2007, 02:40 PM
  3. Can I add more LED's to CPU front panel?
    By Fluxion in forum CNC Machine Related Electronics
    Last Post: 01-30-2007, 05:10 AM
