I want to cut a pinewood derby car on a CNC mill. What feeds/speeds would you recommend for a .25 ball nose endmill?
It totally depends on the quality of your mill. I'm curious what CAM software are you using?
Haas VF2, 15000RPM spindle. GibbsCam 8.7.7
Nice machine. Do you cut wood in it very often? I'd say you could cut as fast as you want. 100 in/min should be easy. 1/4 inch bits can cut pretty fast, and the wood chips will fly.
On my home built router I cut at 40 in/min. Here are pictures of my results. http://flickr.com/photos/davidcousin...7603509563559/
you have time, don't you ? wood is to noble for that ...consider enviroment
