At last the base is filled. I had to wait for my brother's day off for him to come over and help me flip the base for a final pour on top. It now weighs close to 200lbs and is noticeably "deader". A couple pix:
That steel plate fills the old open hole and locates a new center hole for a 1 1/8" bolt to add column to base rigidity.
Bottom-side fills are done. Flipped it and poured the top:
While the top was drying I set out to make a set of leveling feet from hockey pucks for this mill:
I have some minor trimming on the base to do, but I'm about ready to start planning the column fill next. BTW, filling the column bolt holes with wax worked perfectly. Whew!
Best,
BW
