586,080 active members*
3,442 visitors online*
Page 1 of 2 12
Results 1 to 20 of 31
    Apr 2006
    77
    Post Processor for SolidCAM and Mach3
    Hi All,
    I am using SolidCAM and Mach3 as my machine controller. Someone of the Mach3 site posted a SolidCAM/Mach3 post file. Where and how do I install it in Solidworks/solidcam to make this file work? Are there any other solidcam/Mach3 post files available? My soldicam defualts to FANUC.
    Skipper
    Oct 2006
    461
    I've used SolidCAM, but never needed to post process the GCODE, other than to remove the 2nd line.
    I did download the attached file that was labeled "Solidcam post processing for Mach3", but have no idea where I got it. Never tried it... not really sure about how or why I'd need it either. Would like to know though!
    Attached Files Attached Files
    Jan 2006
    On the version of SolidCAM I have, either when you're creating a new job or once you have one created, right-click on the CAM-Parts(<filename>) entry in the tree view on the left of the screen, then change the CNC-Controller to your controller. You will have to put the post-processor definition in the right directory though...
    Dec 2007
    617
    Hi:
    Goto SolidCam in program directory.Expand folder and place post (.gpp extension and .mac machine file) into GPP folder. This is the correct location. You can then configure the program in SolidCam settings to use this as a default(browse and point to mach3.gpp or whatever the name of the post). Whenever you open a new part, you can pick a different post from the CAM definition heading in the main menu bar.
    regards
    Sep 2008
    Mach3 Pre and Post Processor for Solidcam using MILL_&_TURN Operation
    Hello,
    Does anyone has a Pre and Post Processor for Solidcam using MILL_&_TURN operation as a machine_type that produce G-Code for Mach3?
    The Mach3.mac and Mach3.gpp files that is out there are for MILLING operation only.
    Maybe some sharp people out there can help me modified the Mach3.mac and Mach3.gpp files
    to work in MILL_&_TURN operation. (The mac_axes is XZC)
    I have tried to learn the gpptool-example already but I still don't have
    a clue how to modify the files. Sorry, I am not a programmer.
    I would appreciate with any help.
    Phill,
    Feb 2009
    6
    I am in the same situation!
    Does anybody have a 4 axis post processor for Solicam and Mach3?
    Or any help to modify an existing post processor?
    Sep 2009
    I know this is an old post. Did you ever get this working?
    Oct 2011
    Hello my friends
    I'm new to forum and CAM in the universe. I'm starting with SolidCAM and I came across an obstacle, POST-PROCESSOR.
    How do I buy them?
    Thanks!
    Irvando Sampaio
    Sep 2007
    99
    This is the first one I used on SolidCam/Mach3
    Have a newer one on the milling machine with support for 4'th axes, can post that one later.
    Hope this help :-)
    Runar Holm, Norway
    www.maxmekker.com
    Oct 2011
    Thank you very much
    Quote Originally Posted by MaxMekker View Post
    Hope this help :-)
    Thank you very much for help, MaxMekker
    Theses files will be help me. If you can post the other files, gentilez.
    May 2010
    24
    Hey MaxMekker is there any chance you can upload that 4th axis post for solidcam to mach3?
    Looking forward to giving it a go on my new vertex RT
    Cheers
    ad
    Apr 2012
    Bump
    Anyone ever managed to get the 4th axis to work with Solidworks + SolidCAM + Mach3?
    That would be brilliant to find out as we are aiming at making software purchace very soon and need to have the perfect combo for our 'limited' budget!
    Jun 2012
    looking for post for NHX4000 mori in sloidcam
    Sep 2007
    99
    To the people that ask me for 4th axis, if and when I get it to work like it should I will post it.
    But sadly I haven´t had to much time because of work to finnish the file.
    Runar Holm, Norway
    www.maxmekker.com
    Jul 2013
    4
    Re: Post Processor for SolidCAM and Mach3
    hi, sir i want to customize post processor on solidcam for Siemens 840D. want to know how to customize existing (default) post processor files (e.g. .gpp and .mac files)
    Sep 2014
    help
    I need file Mach3 plasma.post to sheetcam, becouse current available files not suport Mach3.
    Thankyou friends.
    I am from Bolivia, My english is bad.
    Sep 2014
    Disculpen, el problema se resolvio usando el post procesador Mach2 plasma.post el problema fue que en el Mach3 no estaba configurado el IJ incremental.
    Gracias, tal vez este detalle les podria servir a otros.
    Sep 2014
    Sorry, the problem was solved using the post processor Mach2 plasma.post the problem was that the Mach3 was not configured incremental IJ.
    Thanks, maybe this detail they could serve others.
    Oct 2014
    need help
    Hi
    i have fagor 8055 as my machine controller(lathe)...any one have Post Processor for any cam using MILL_&_TURN Operation
    thank you all very much
    Oct 2014
    need help
    Hi
Page 1 of 2 12
  1. Solidcam / Haas VF-2 / Post Processor
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-02-2016, 03:15 PM
  2. Need Fadal post processor for Solidcam
    By bird19 in forum Post Processor Files
    Last Post: 05-16-2014, 02:23 AM
  3. solidcam mach3 4th axis post processor
    By mioduz in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-07-2014, 01:04 PM
