586,055 active members*
4,273 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Figuring out Stepper Wiring
Results 1 to 3 of 3
    Jun 2004
    19
    I have some surplus steppers that are 6 wire. What is the easiest way to suss out the wiring?
    If I randomly hook 3v up to the wires can I fry anything? What am I looking for when I do this? Does a stepper respond to hi/lo transitions or is constant voltage ok?
    Mar 2004
    106
    I found this good tutorial about stepper motor, it will certainly answer all of your question. It have a section on how to find the correct wiring sequence.
    http://209.41.165.153/stepper/Tutorials/Tutorials.htm
    CrazyRonny
    Jun 2004
    19
    Hey, thanks for that. Very useful.
    Regards
    Ben
  1. 8 wire Stepper motor wiring connection
    By hornet in forum Stepper Motors / Drives
    Last Post: 01-25-2013, 07:52 AM
  2. Stepper Wiring
    By JW Peters in forum Stepper Motors / Drives
    Last Post: 06-04-2005, 01:17 AM
  3. Stepper motor wiring
    By smitty in forum Stepper Motors / Drives
    Last Post: 03-05-2005, 11:58 PM
  4. stepper wiring and parameters
    By Ferenczyg in forum CNC Machine Related Electronics
    Last Post: 04-12-2004, 06:14 PM
  5. Stepper Motor Wiring Questions
    By TRC1 in forum CNC Machine Related Electronics
    Last Post: 08-16-2003, 03:03 AM
