586,331 active members*
4,668 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > potentiometer and jumpers
    Jun 2007
    36
    Hi i need to set the potentiometer and jumpers on my cnc board, but i have lost the instructions could anybody explain how i do this.
    I am using the 3 axis board
    and the 8wire 1.85Nm from motion control products.
    David
    Sep 2007
    32
    Hi, David,
    There are different settings for different boards. What board and Rev, (revision), number, do you have? Also, it would help to know about how old it is. Given that info, I've probably got the instruction sheets that has the info you need.
    All the best
    MB
    www.mikebeck.org
    Jun 2007
    36
    Sorry, its the 3axis hobbycnc pro rev 1.
    David
    Sep 2007
    32
    Dave,
    If you have a first-run board, the info is printed right on it. If current run, after first of the year, it's not. I'll type it all out for you.
    MB
    www.mikebeck.org
    Jun 2007
    36
    Hey thanks, i did some digging around and found instructions, Thanks for your help.
    David
  1. x2 potentiometer possibly bad, help
    By h_2_o in forum Benchtop Machines
    Last Post: 12-13-2006, 05:18 AM
  2. 4th Axis Prewired (Jumpers)
    By Fudd in forum Fadal
    Last Post: 02-18-2006, 01:21 AM
