586,103 active members*
3,181 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X3/SX3/G0619/G0463 > Seig X3 Conversion with Deluxe CNCFusion Kit
Page 1 of 19 12311
Results 1 to 20 of 367
    Jul 2007
    675
    In this thread I plan to complete the CNC conversion using the cncfusion kit, build an 8020/plexiglass enclosure, and build a combination PC/driver tower.
    I've had my X3 for about 3 months now and have manually milled myself into a stupor. Issues with backlash in the stock lead screws and not having enough time to concentrate really bit into "fun" time. CNCing the mill just seemed right .
    Here's a shot of my present set up: mill, dual head fogbuster-best money I've ever spent, and the custom made stand (figures 1 & 2). Here's how the kit arrived (figures 3 & 4). I was surprised how nice the precision ballscrews were. I was expecting the black roton type screws but these are up a notch :cheers:.
    First step is to break the mill down and remove all of the stock motion components. I found that doing this while singing "ding dong the lash is dead (The Wizard of Oz)" made the process go a lot quicker (neglected to take pics).
    More to come
    Attached Thumbnails Attached Thumbnails P2260052.jpg   P2260054.jpg   P2260055.jpg   P2260058.jpg
    Nov 2005
    655
    Congrats,
    How messy is the fogbuster? Looks real nice!
    I'm jealous, your shop is way too clean.
    Are you going to build the enclosure on the current bench?
    I'm going to have to build me another bench when I get around to building an enclosure for it. It seems I didn't allow for the motors and mounts. oops:withstupi
    Cheers,
    Jack
    Walking is highly over-rated
    Jul 2007
    675
    Quote Originally Posted by tauntdesigns View Post
    Congrats,
    Cheers,
    Jack
    Thanks, you caught the shop on a good day.
    Mess? The fogbuster leaves very little mess. I don't even have a drainage system; don't need it. At most a small 1" puddle of coolant may develope on the part so I just soak it up with a shop rag :wee:
    Yes, I will build the enclosure on the current stand. To clear the motors and extra equipment I'll have to arc out the sides 45 degrees. I'm CADing the plans now, but I need to finish the conversion first to take measurements.
    Want to see something cool? Wait till you see the electronics case!
    Jun 2003
    232
    Are you using the $949 "Small-Mill Deluxe CNC kit with PREMIUM BALLSCREWS"?
    Thanks.
    Jul 2007
    675
    Quote Originally Posted by kanton View Post
    Thanks.
    Yep, that's the one. I also purchased the upgraded helical couplings.
    __________________________________________________ ____________
    The first time I broke down the mill for cleaning, it took almost a week. This time it only took 3.5 hours. Here are a few shots of the breakdown (figures 1-3). All the parts on the floor are never going to see the light of day again. The parts on the bench will be re-used.
    Started buying my electronics today too. Who knew $900 bucks could go so fast . Here's what I ordered so far:
    Kelinginc
    a) Gecko drives 203V (3) @ $139.00 ea
    b) 425 oz Stepper Motors (2) @ $54.00 ea
    c) 640 oz Stepper Motor (1) @ $89.00
    d) 1000W Power Supply w/ 12v & 5V outputs (1) @ $189.00
    CNC4pc
    a) C11G Break Out Board (1) @ $109.00
    More to come
    Jul 2007
    675
    Lets try it with the pictures this time.
    Attached Thumbnails Attached Thumbnails P2270053.jpg   P2270056.jpg   P2270060.jpg
    Sep 2006
    1738
    Looking good, Love these types of threads!
    -Jason
    Jul 2007
    675
    Quote Originally Posted by SpeedsCustom View Post
    -Jason
    Thanks. Love what you did with the Taig.
    Something I didn't expect to encounter....
    The cncfusion kit requires you to re-use the original Z axis thrust bearings. These are sub-par IMHO (figure 1). For one, the entire leadscrew was rusted therefore the thrust bearings were rusted onto it. Took many well placed taps with a hammer to get them off. Also in the middle of the angular thrust bearing there's a dent. This slightly restricted rotation when I tested it. Never could tell when it was on the mill though. Looks like I'll be shoping a mcmaster-carr today too .
    Also found these really nice limit switches from honeywell: Link
    Jul 2007
    675
    Again with the pic
    Sep 2006
    1738
    MRM- Ah so you have seen it Still so much work too be done. So much fun, setting up everything, trust me, I have A LOT!
    I'll be looking closely at this thread. Keep it up!
    -Jason
    Nov 2005
    655
    Quote Originally Posted by MRM RCModels View Post
    Started buying my electronics today too. Who knew $900 buck could go so fast . Here's wheat I ordered so far:
    Kelinginc
    CNC4pc
    Yea, $900.00 doesn't go as far as it use to........
    A couple of 'heads up' (fyi type thing)!
    That power supply's 5v supply doesn't have enough amps to run the BOB. It has 1amp regulated and the BOB requires 2amps. I ended up buying the A4 power supply from CNC4PC. It comes with a panel mount plug.
    http://www.cnc4pc.com/Store/osc/inde...5670ef07367b3b
    Something else about the BOB.. Arturo said it was on the older Revision boards, so it shouldn't happen with yours but just in case here's a description of my BOB problem.
    "My charge pump doesn't work, unless..... I start up mach3 before I
    power up the BOB, then it works fine. If I re-start mach3 without
    turning off the BOB first, the charge pump stops working properly
    until I turn off the BOB and re-start it too."
    I wired my motors (425's bi-polar parallel and 640 bi-polar series) That way both motors fit the power supply better.
    Looking good,
    Jack
    Jul 2007
    675
    Looking good,
    Jack
    Thanks for the heads up. I decided to go with the 1440W/20A & cnc4pc 5V/12V power supplies instead. I did this because my next machine will be much bigger with 640 oz NEMA 34s on all axis’s (sp?) and I plan to run both machines from the same electronics station on a parallel port switcher. Matter of fact, I'm making this machine for the sole purpose of cutting parts for the big one .
    On the thrust bearings hunt, I've come to the conclusion that the X3 uses regular ABEC-1 skate type bearings on the Z Axis. I visited several stores trying to find Angular Thrust Bearings (ATB) to fit a 12mm diameter shaft with an Outer Diameter (OD) of 28mm (the bearing holder is 28mm). All the stores had ATB for a 12mm shaft, but the outer diameter was a minimum of 30mm :boxing:. I then tried looking at regular bearings and they all were 12mm shaft and 28mm OD. I'm not happy, but not surprised either. ATB are 2-3 times the cost of the ABEC-1s. Looks like my first project will be to machine wider bearing holders to accept the superior ATBs.
    The ones that came with the X3 weren’t all that great to begin with (rusted, dented, and old), so I'm going to change them out with new ones of the same type. VXB had the Thrust Bearings, mcmaster-carr had the ABEC-1s: part# 2337K122.
    More to come
    Nov 2005
    655
    I'm glad it (heads up) helped,
    Thanks for the info on Z-axis bearings.
    With that power supply you'll want to wire the 640 oz/in motor series or it (could/will) burn up. At least that's what the G203v manual says: Quote from manual:
    In all cases the power supply voltage should be no less than 4 times or no more than 20 times the motor’s rated voltage. The motor may not run as smoothly as possible if the power supply voltage is less than 4 times or more than 20 times the motor’s rated voltage. A power supply voltage greater than 20 times the motor’s rated voltage may overheat and damage the motor.
    On the BOB make sure and set the jumper on the board for COM to be ground.(not +5v)
    G203v (TERM. 10) COMMON Connect this terminal to the controller ground output
    The G203v differs from all the other geckodrives on (term 10). Not sure about the new G250 & G540 products.
    If this is stuff you already knew, please excuse me... it's just fresh on my mind. It kinda' stuck with me. I bought all my stuff and then had these OH S___ moments.
    Can't wait to see more,
    Jack
    Nov 2005
    655
    Oh yeah..... my 5v/12v power supply from CNC4PC didn't come with a AC power cord. The picture on their site doesn't show one. I had an extra PC power cord that worked so, if you don't have an extra power cord laying around......................
    Jul 2007
    675
    Jack
    Thanks for saving my stepper motor. I read the gecko manual but didn't comprehend the limitations of the 640 oz stepper. Now that you mention it, I do have a extra pc power cord laying around......
    __________________________________________________ ______________
    Today I installed the X and Y Axis for the mill. First, I roller the base on its side and removed the original ballnut mounting block. Then, grinded down Y Axis the alignment pins on the base (figures 1-4). I thuought about modifying the cncfusion kit to use them, but decided that it would take too much time. On the other hand, it would make aligning each axis so much easier .
    Attached Thumbnails Attached Thumbnails P3010051.jpg   P3010052.jpg   P3010054.jpg   P3010055.jpg
    Jul 2007
    675
    Continued:
    Little bit of locktite in the right places goes a long way. I then mounted the Y Axis ballscrew assembly onto the base (figure 1). Now it was time to remove the locknuts and mount the table to the base. Here is my biggest qualm about this kit: WHY DID THEY NOT INCLUDE "C" SPANNER WRENCHES WITH THE KIT!!!!!!. These are not as common as I thought so I hade to imagineer way to get the locknuts off. My solution was to use a set of vice grips with a shop rag around the teeth to loosen the nut. This way I wouldn't destroy the nut in the process (figures 2 & 3).
    Attached Thumbnails Attached Thumbnails P3010059.jpg   P3020068.jpg   P3020072.jpg   P3020067.jpg
    Sep 2006
    1738
    Looking real good, love the photos.
    -Speed
    Nov 2005
    655
    Yeah, I like looking at pictures too.
    Keep up the good work,
    Jack
    May 2007
    715
    I just went through the same thing with the bearings. I wasn't able to find anything remotely close to the 12mm bearings, but I did find some needle bearings from MSC direct that did the trick. Much smoother operation and it was about $18 for the complete set of washers and bearings.
    03380904 Thrust - Bearings Outside Diameter: 0.9380 In. Thickness: 0.078 In. Inside Diameter: 0.5000 In. Material: Steel Style: Needle Cage
    03381076 Thrust - Bearings Outside Diameter: 0.9370 In. Thickness: 0.032 In. Inside Diameter: 0.5000 In. Material: Steel Style: Flat Race
    Worked out great! You'll need 2 flat race washers for every 1 Needle cage.
    Jun 2003
    232
    What is the expected accuracy gain in using the $949 "Small-Mill Deluxe CNC kit with PREMIUM BALLSCREWS" rather than the $569 ballscrew kit? Are there any other benefits in using the more expensive kit?
Page 1 of 19 12311
  1. X3 conversion using the CNCFusion Deluxe kit
    By tauntdesigns in forum Benchtop Machines
    Last Post: 08-26-2014, 01:44 AM
  2. Seig X1 mill - Initial Conversion Design - pdfs
    By jeffo2001 in forum Benchtop Machines
    Last Post: 02-20-2009, 02:47 PM
  3. Aussie X3 with CNCFusion Deluxe Kit
    By Rodm1954 in forum Benchtop Machines
    Last Post: 01-11-2008, 10:09 AM
  4. x3 conversion w/ cncfusion's deluxe kit, Grex, G320's & keling servos
    By yantra3d in forum Vertical Mill, Lathe Project Log
    Last Post: 08-24-2007, 11:04 AM
  5. CNCFusion 9x20 lathe conversion?
    By thumper650 in forum Mini Lathe
    Last Post: 04-24-2007, 07:00 AM
