586,096 active members*
3,713 visitors online*
Results 1 to 8 of 8
    Feb 2008
    Unhappy sharp sv-2412
    Hello folks!
    I'm new to this kind of communication, but will give it a try. We have a Sharp mini mill here where I work. I am trying to input a program using a lap top computer.
    The machine does not have a floppy drive to use that I guess is the normal thing. I do have the computer hooked up and it will send a program to the machine and actually downloads it into the memory. I want to run the program from the computer. I hope someone can help me with this!!
    Dec 2003
    24221
    Not sure of your question? Do you want to run the machine from the PC? What type of controller is it, or it a PC based control?
    Doesn't that have a Fanuc controller?
    Al.
    Albert E.
    Jun 2006
    629
    dude wants to run it dnc. We'll need more info.
    "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
    Aug 2005
    578
    I haven't done any DNCing on mine but you use the remote button...
    Dec 2003
    24221
    If it is a Fanuc, on most you have to enable a PMC bit in the ladder, via a panel switch if the option is wired in by the MTB.
    Al.
    Albert E.
    Feb 2008
    Problem solved
    Thank you gentlemen for the input about my problem with the Sharp SV-2412!
    I spent most of yesterday searching the net and discovered that I needed some more software. I downloaded a trial version of Dostec DNC. I did have some troubles setting everything up, but the the tech folks at Dostek are great and got me running in about an hour! Thanks again, Terri
    Aug 2005
    578
    It's in the Fanuc manual that came with the machine
    Mar 2008
    6
    use a flash card
  1. Sharp CNC V 2412 Question
    By pshsguy18 in forum Sharp CNC
    Last Post: 01-23-2010, 04:15 AM
  2. Sharp SV- 2412 CNC Machine Question
    By pshsguy18 in forum Uncategorised MetalWorking Machines
    Last Post: 02-16-2008, 06:35 AM
  3. Sharp SV-2412
    By Larry B. in forum CNC Machining Centers
    Last Post: 10-12-2007, 02:58 PM
  4. Sharp 2412 tool changing problem
    By longcut in forum CNC Machining Centers
    Last Post: 09-15-2007, 11:02 AM
  5. Postprocessor for Faunc Oi Mate-MB on Sharp 2412
    By Mickey_D in forum SprutCAM
    Last Post: 07-21-2007, 11:51 AM
