586,036 active members*
3,558 visitors online*
Page 3 of 5 12345
Results 41 to 60 of 95
  1. #41
    Oct 2006
    27
    Hi Tony I have a question. I have Photo V-carve and use it extensivley as well as 3d machinist. Are you able to import either of these toolpaths into a design in Cut2D the same way you can with V-Carve Pro? I have always been planning on buying V-carve anyway but the price of cut2d is just so appealing for the features that I would actually use. I looked at the comparison on the web site and couldnt find anything related to this so I am assuming not.
    Thanks, Ryan
  2. #42
    Aug 2005
    597
    Hi Ryan,
    Cut2D will import the toolpath files from both Cut3D and PhotoVCarve and allows the toolpaths to be positioned, previewed and saved in the same way that VCarve Pro does.
    Thanks for the feedback about the web site and we must get this added to the feature list.
    I hope this helps,
    Tony
  3. #43
    Oct 2006
    27
    Wow that was quick. While you were typing that I was looking at the site again and I did find refrence to this feature.. in bold letters actually Either it was there all along or you guys made the changes to the site that quick.
    Anyway, awesome product. At that price I'm sure it will be a hit. I will be buying it, and possibly upgrading to vcarve if I ever get to the point that I need more features.
    Thanks, Ryan
  4. #44
    Aug 2005
    597
    Finished!
    Jeff Arnett (Wood Time Inc) has recently completed his new clock design
    using Cut2D to machine the individual parts. And below are a few more pics
    of the parts ready for assembly and the finished master piece.
    Great work Jeff!!
    Tony
    Attached Thumbnails Attached Thumbnails Parts.jpg   Slice_of_Time_in_Walnut_and_Maple.jpg
  5. #45
    Jun 2008
    475
    I've been trying out Cut 2D and really like it, I'm about ready to buy it but have a question.
    Although I will mostly be using this and Mach3 for making metal parts on my X2, does Cut 2D work for isolation routing and drilling PCB's ?
    I'm tired of the ferric chloride method for one off prototypes.
    Steve
  6. #46
    Oct 2006
    975
    Quote Originally Posted by SScnc View Post
    Steve
    Hi Steve,
    I have no experience with isolation routing or drilling PCB's but my guess is that if it entails 2D machining Cut2D will do it and do it well. I am using Cut2D with my X3 and it has done everything I have tried with ease and dependability. Hopefully someone with that particular experience will reply.
    Regards,
    Wes
  7. #47
    Sep 2007
    55
    I'd suggest using Eagle (a free version is available) to layout the PCB. A free ULP (user language program) is available that will generate gcode to do exactly what you want. Here's there web site:
    www.cadsoftusa.com
    There is also a Yahoo group dedicated to this:
    groups.yahoo.com/group/pcb-gcode
  8. #48
    Jun 2008
    475
    Thanks metalworkz, I've seen some of your work and very impressed. I appreciate your opinion.
    Rgoldner, Thanks for that info. I've been using PCB Wizard pro and like it allot and it will export CAM data, just not sure about using it to do this yet. I'll try exporting to Cut 2D later tonight and see what it can do.
    I know about Eagle but didn't know about the free version, I'll check it out and see how it compairs to PCB Wiz Pro.
    Thanks allot,
    Steve
  9. #49
    Apr 2006
    87
    I find it odd that Cut2D doesn't seem to allow the user to thru-cut on an inner shape. For example on the connecting rod tutorial from Vectrics website, the bore holes for the crankshaft and gudgeon pin. Why spend the time and wear out the bit pocket machining the entire area of the bore holes when all you want to do is cut all the way through along the circumference? Is this going to be addressed soon and if so, will the program also support leaving tabs on those inner waste areas?
  10. #50
    Oct 2006
    975
    Quote Originally Posted by CanSir View Post
    Hello,
    The Cut2D program will let you thru-cut and it already has interactive tabs incorporated into it. I have not viewed the tutorial you speak of, but I have done parts with cutouts and instead of using the pocket routine just use the profile option and you can drop the tabs where you would like them to be. The program will warn you that unless you are using a sacrificial plate etc. the operation could damage the work table by thru cutting at a depth greater than the material thickness, but it lets you choose to click OK and proceed or cancel the operation. If you have not done so already they have a functional demo available to try and you can test drive it. Check it out!
    Regards,
    Regards,
    Wes
  11. #51
    Apr 2006
    87
    Quote Originally Posted by metalworkz View Post
    Hello,
    Regards,
    Thanks metalworkz! I'm in the opposite situation as you. I've looked at the tutorials, but I haven't run the application. I wonder if the tutorial was written for an earlier version of the software because I can't see why they would pocket the bore holes instead of profile cutting them. The tutorial already had a realistic example of why and how to use the pocket option. The clock gear tutorial did the same thing if I recall correctly.
    Well, it looks like I've run out of reasons not to buy Cut2D now. I'm going to immediately start saving for the VCarve upgrade though too.
    :rainfro:
  12. #52
    Sep 2007
    34
    I have been using Cut2D for awhile now and find it extremely user friendly. However. I have one question. While doing a profile is it possible to specify a starting point for the tool?
  13. #53
    Aug 2005
    597
    Hi Etced,
    Glad to hear Cut2D is working well for you.
    Yes - the Start Point can be controlled using the Node Editing Tools to set the Start Node.
    Select the vector to Profile and press N to start Node Editing mode
    The Start Node is drawn in Green
    Place the cursor over the Node that you wish the cutter to start / plunge at
    Click Right mouse button and select > Make Start Point
    The Profile machining will no start at this point on the vector
    The Node Editing Tools can also be used to Insert / Delete, Smooth / Unsmooth Nodes and also convert spans to and from Arcs / Lines / Bezier Curves.
    I hope this makes sense and helps.
    Tony
  14. #54
    Sep 2007
    34
    Hi Tony,
    Thanks for the fast reply. Works great.
    Ed
  15. #55
    Jan 2006
    387
    If I've already got VCarve Pro 4.6, do I need Cut2D for anything? Or will VCarve Pro 4.6 do everything Cut2D can do?
    I want to support Vetric- the best software I've used. handles everything I've had to do so far, with PhotoVcarve, Cut3D, and Vcarve Pro. I intend to keep my software up to date - need to talk to Tony ( hey Tony! ) about a Lifetime Subscription Plan!
  16. #56
    Aug 2005
    597
    Hi Ed,
    You are spot on - VCarve Pro does everything in Cut2D + all the other stuff, so no need to get Cut2D
    Thanks for the positive feedback on the software, very appreciated.
    Tony
  17. #57
    Jan 2006
    387
    Have there been any releases for VCarve Pro and Cut3D and PhotoVCarve this year? I think my free upgrade time ran out in December. I have 4.6 of VCarve Pro.
  18. #58
    Aug 2005
    597
    You haven't missed any releases. We don't typically discuss release dates because it's commercially sensitive - customers wait so sales stop - plus we are never sure how long some of the projects will take to code, debug and test.
    Tony
  19. #59
    Jan 2006
    387
    No problem, Tony. I coudl have just gone to the Vectric site to see for myself, thanks much for answering
  20. #60
    Jun 2008
    475
    I finally purchased CUT2D today !
    I'm happy with it and have run a couple of simple operations with it on my X2.
    I have a question though, I want to do the opposite of a pocket, that is mill everything down around a shape, say a 1 in. x 1 in. square x 1/2in. high "protrusion".
    I can't think of what this is called at the moment.
    What is the procedure on that ?
Page 3 of 5 12345
  1. Replies: 5
    Last Post: 03-18-2012, 09:17 PM
  2. Vectric Cut2d output to Mach3
    By msimpson99 in forum DIY CNC Router Table Machines
    Last Post: 11-15-2010, 01:01 AM
  3. Cut2D - Can It Do this?
    By noisillator in forum Vectric
    Last Post: 06-19-2009, 05:43 PM
  4. G CODE NOT WORKING ANYMORE from Vectric cut2d and 3d
    By TZak in forum LinuxCNC (formerly EMC2)
    Last Post: 03-01-2009, 04:51 PM
