586,103 active members*
3,286 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Need some help with speeds & feeds
Results 1 to 7 of 7
    Apr 2007
    Hello everyone I'm a first time poster. We are cutting some .017" & .025" wide slots by approx. .050" deep. We are going to use 2 flute centercutting carbide endmills. The material is 6061 aluminum. The max rpm is 10000. Would anyone have some starting points for these? Thanks.
    Larry
    Jul 2005
    12177
    Have you looked into using a slitting saw?
    If you are doing a lot of these it could be worth the cost of getting a right angle head so you can use this.
    A 0.017" wide slot 0.05" deep in 6061 is going to be a challenge and the cutting time much, much longer than with a slitting saw.
    I would not even try with an endmill.
    Apr 2007
    Geof, it's not a thru slot. There is two different parts with approx. 50 slots each about a 1/4'' long. They are to locate parts by their flange to be laser engraved.
    Oct 2005
    672
    I am currently running parts with a .027" centercutting carbide endmill. RPM is 7500, plunge speed 1ipm, feed 3ipm. I take .010" on each pass. Not quick but no broken bits yet.
    Jul 2005
    12177
    .027 is larger than .025 and much larger than .017. How deep are you going with .027?
    A slitting saw does not require a throuh slot; plunge it in like you would with a Woodruff cutter. If it is necessary to have an end to the slot to locate parts simply put another slot at 90 degrees and insert a piece of shim as a stop.
    Oct 2005
    672
    The endmill is going through a total of .030". First cut is at Z-.235" and last cut at Z-.265". Makes three passes removing .010" each time. More specifically, I'm doing these. I have used .0156" endmills before as well. Patience is the key obviously.
    Use as much rpm as you can get away with, and as big a dia. cutter as you have room for. Your depth cuts will not be more than .002-.005. Set a feedrate to get about .0001/.0002 chip load. 4ipm at 10k rpm is .0002 chip load. Do not plunge into your cuts. Either pre-drill to within .001 of bottom of slot or ramp into the cut at about 2-3 degrees. Harvey Tool makes really great miniature endmils. Use as short a cutter as you can, and lots of coolant to flush out the chips. Good luck
  1. speeds and feeds
    By bdrmachine in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-12-2008, 02:15 PM
  2. Speeds and Feeds
    By CLP CORP. in forum WoodWorking Topics
    Last Post: 12-07-2007, 07:38 PM
  3. Speeds and Feeds
    By wdp67 in forum Benchtop Machines
    Last Post: 07-10-2007, 08:06 AM
  4. feeds and speeds
    By rchprks in forum MetalWork Discussion
    Last Post: 07-18-2006, 12:48 AM
  5. feeds and speeds
    By lito in forum MetalWork Discussion
    Last Post: 03-14-2005, 02:58 PM
