586,655 active members*
3,066 visitors online*
    Jun 2003
    1365
    Mach 2 not loading files
    Hey, I am trying out mach2 and I cannot load a file, I click file load, open the *.nc file that I want and nothing happens, I tried 2 different versions of mach2 and mach1, In Mach1 I tried writing my own stuff where you can and when I go to the next line or whatever it just eraces it.
    This is on my second computer that I want to run as my controller, Ill try my main pc and see if I have the same problem.
    Jon
    Jun 2003
    1365
    Crap, I got it to work, I couldnt load these files over the network for some reason, that kinda sucks. Ill have to copy them to my hdd first.
    Thanx anyway
    Jon
    May 2007
    6
    Hi I am also having great trouble loading a file ( I can't load a thing)I have mach3 software machine is a syil super3 mill ----just testing everything out which is sort of going ok except the loading part---- do I need a wizard or is there somthing I'm not doing.
    Thanks in advance
    Apr 2006
    3498
    send us the file...we will add some virus in it... then load that virus into ur MACh.. it will not only cure ur Mach but also ur Operating system...(Joking)... post ur file here ..we will see it on our mach...
  1. Replies: 14
    Last Post: 01-15-2010, 02:06 PM
  2. Mach / geckos or DTLLC drivers
    By zcases in forum Mach Software (ArtSoft software)
    Last Post: 01-12-2007, 02:06 AM
  3. Mach 2 and settings
    By tauscnc in forum Commercial CNC Wood Routers
    Last Post: 05-25-2005, 03:05 PM
  4. I need Major Help! / Mach 1
    By AgentD in forum Mach Software (ArtSoft software)
    Last Post: 02-12-2005, 06:23 PM
  5. Proper Computer and Chip for Mach 1
    By HomeCNC in forum Mach Software (ArtSoft software)
    Last Post: 03-18-2004, 04:14 AM
