586,121 active members*
3,086 visitors online*
Thread: Fanuc 18T
Results 1 to 8 of 8
    Aug 2004
    68
    Fanuc 18T
    Just got a Whacheon Hi-ECO 31A wit the Fanuc 18T control. No book. Can't get the machine to take a program from the computer. We use an old Procom program. I get an alarm, number is 086. Also, the machine has info on using the tool setter, any thoughts appreciated.
    Paul in OKC
    2932
    Paul,
    An 086 alarm can be caused by incorrect cable wiring from the CNC to the PC.
    CNC <-----------> PC
    DB25 ----------- DB9
    1 <-- shield
    2 <---------------> 2
    3 <---------------> 3
    7 <---------------> 5
    Pins 4 & 5 are jumpered on the CNC end.
    Pins 6, 8 & 20 are jumpered on the CNC end.
    Aug 2004
    68
    I use the same set up to load 2 other machines, a Daewoo Puma lathe with a 15T, and a Haas VF3 machinig center. Tried to match all the numbers in the system set up.
    2932
    What do you have in Setting - I/O Channel (parameter 20)? It should be 0 or 1 for RS-232. What works on the Haas won't necessarily work on the Fanuc, but the 15T cable should work. If your cable is wired with 6-8-20 jumpered then you may have a bad connection internally or a bad comm board.
    Aug 2004
    68
    I will check it out. Thanks.
    It is at 0.
    Jan 2006
    121
    can you send programs from CNC to your PC? If it works in one direction and not the other, most likely not the parameter settings.
    Aug 2004
    68
    Nope, tried that too. I feel like we are just missing something obvious. Is there a parameter setting for communication?
    Jan 2006
    121
  1. GE Fanuc & FANUC proprietary posts
    By cncadmin in forum Fanuc
    Last Post: 01-12-2022, 07:33 PM
  2. FANUC & GE FANUC Repairs
    By RRL in forum News Announcements
    Last Post: 04-17-2011, 05:50 PM
