586,069 active members*
3,444 visitors online*
Results 1 to 6 of 6
    Sep 2003
    1469
    Question Tabs How and Where?
    A response from Joe in his 4X4 Hybrid thread (I didn't want to hyjack that thread): "Its a feature in V-Carve Pro you can add them automatically or place them where you want and specify all the parameters of them, i.e. width and height, 3d or not."
    Other than "V-Carve" what is the easiest and cheapest way to have tabs in your drawings?
    Aug 2004
    3215
    If you do not have a program which can insert them for you, I would draw a duplicate of the part outline on another layer in Cadd off set it 1/2 the bit dia. and manually delete the line segments to exclude the area there you want tabs i.e, ------ ------ the space being the tab and machine the line directly for your final pass, If you have say 0.75" stock, machine everything as you would normally but on the final pass on the part cutout off (machine to a depth of 0.625") leaving the final 0.125" for your tab machining.
    Hope that kinda explain how i would go about it.
    Joe
    Sep 2003
    1469
    Quote Originally Posted by joecnc2006 View Post
    Joe
    Thanks Joe,
    I'm new to cad drawing and I keep forgetting the value of layers. That will do it.
    Jul 2006
    123
    lazycam has tabs also, they are just harder to find
    dan
    Jun 2004
    6618
    Just for the searching aspect of this thread, Sheet Cam also has tabs. They are very easy to use. Any size or thickness.
    Lee
    Quote Originally Posted by Mr.Chips View Post
    Check Vectrics new Cut2D for $199. I didn't see it listed, but I'm assuming it has it. Check out the demo, it's basically Vcarve Pro without the V-carving.
  1. Rhinocam and Turning/Tabs
    By Moondog in forum Rhinocam
    Last Post: 09-23-2007, 04:05 PM
  2. Problem using tabs
    By LongRat in forum SheetCam
    Last Post: 08-06-2006, 09:39 AM
  3. TL-1 Missing Tabs
    By elaganis in forum Haas Mills
    Last Post: 06-19-2006, 06:24 PM
  4. Adding Tabs With MasterCam V9
    By mmcclain02 in forum Mastercam
    Last Post: 01-20-2006, 08:53 PM
  5. Tabs in V9
    By MikeA in forum Mastercam
    Last Post: 03-21-2004, 12:55 AM
