586,072 active members*
4,389 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > WTB: Lead screw nuts for Bridgeport Style MSC (Taiwan) knee mill for X and Y
Results 1 to 6 of 6
    Mar 2007
    29
    I need the leadscrew nuts for our MSC knee mill, it is Bridgeport style knee mill made in Taiwan by Cheng Ki Co.
    Please LMK. Thanks.
    Jan 2007
    64
    Check H&W Machinery in Fort Wayne Indiana. Tell Henry that C.J. sent you.
    Jan 2007
    92
    lead screw nut repair
    If your lead screw nuts are just sloppy, you can usually split them and take up the slack with the retaining screw. See the Bridgeport operators manual in the
    http://finance.groups.yahoo.com/grou...mill_manuals1/
    for a photo. The file should be labeled Operators manual 1981, and the diagram of the table shows where to split the X-axis nut (somewhere in the middle). I have also seen a technique where the nut is split about 80% through and the retaining screw forces the gap to close. I think the full split nut would be better since it should wear more evenly.
    May 2006
    179
    I have them in stock.
    Kirk
    Majestic Machinery
    626-336-2350
    Mar 2007
    29
    Quote Originally Posted by MicroMill View Post
    Will try, thanks, .
    Quote Originally Posted by bbutcher85710 View Post
    I'm not sure if it will work, this machine that I need the nuts for isn't a Bridgeport and some parts vary among the original Bridgeport.
    Quote Originally Posted by ktb100 View Post
    Kirk
    Majestic Machinery
    626-336-2350
    Will try, Thanks, . Could you please send a quote for the 2 nuts?
    May 2006
    179
    Nuts run $35.00 a set. $199. for (4) nuts and (2) screws (up to a 12" x 54" table)
  1. How much is a new Bridgeport knee mill?
    By squale in forum Bridgeport / Hardinge Mills
    Last Post: 02-26-2011, 08:14 AM
  2. lead screw nuts wanted
    By Bill Harrison in forum MetalWork Discussion
    Last Post: 03-04-2008, 07:37 AM
  3. Bridgeport knee mill variants?
    By PastyPies in forum Bridgeport / Hardinge Mills
    Last Post: 11-23-2007, 11:41 PM
  4. Rotating lead nuts
    By Tom Brown in forum DIY CNC Router Table Machines
    Last Post: 09-29-2006, 03:25 PM
  5. Bridgeport CNC Knee Mill Enclosure
    By Jadaan27 in forum Bridgeport / Hardinge Mills
    Last Post: 06-25-2006, 04:28 AM
