586,042 active members*
3,731 visitors online*
Thread: Bone screws
    Jul 2004
    Talking Bone screws
    Hello,
    Did any body knows how to machine bone screws thread with single point insert in a CNC lathe?
    Mar 2008
    443
    Not as nice & easy as thread whirling, but do-able. I've done it with G32 (Fanuc 16i-TB control) successfully. You'll have to get the screw profile ground into a custom insert, so I might recommend calling Etco Tool (Waltham MA) as they were my source for inserts that perfomed very ell in the 6AL-4V titanium alloy I had to cut.
    You can do the first tapered section with a "R" value for the taper, then match the next straight section to it. Depending upon machine and control, it might use G33 or other codes to make thread section match up.
    May 2010
    Bending
    I use same method, and even profile the inserts myself, but without a tailstock (my machine hasn't got any) there is a limitation as the screws bend
    I hope I could be able to upgrade to whirling, but with these prices, I doubt.
    Did anyone ever consider homemaking a thread whirling head ?
  1. ball screws
    By morbius in forum Bridgeport / Hardinge Mills
    Last Post: 06-05-2007, 09:37 PM
  2. Ball screws, Acme screws, threaded rod
    By DJ Morrow in forum DIY CNC Router Table Machines
    Last Post: 03-22-2007, 06:39 PM
  3. Take out screws
    By vmax549 in forum Bridgeport / Hardinge Mills
    Last Post: 02-13-2006, 05:22 PM
  4. Why doesn't anyone use THK and NSK Rolled Screws?
    By Noah in forum Uncategorised MetalWorking Machines
    Last Post: 07-19-2004, 06:58 PM
  5. What Screws To Use For Mdf?
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 04-27-2004, 11:28 AM
