Hi Sonic.
I have not noticed any problems to date and I don't expext to as the point loading is probably quite low. If you look at the pics you see that the epoxy is getting squeezed between a fairly stiff 8020 style extusion and a very stiff I beam. These both act as pritty big washers to spread the load. If I was very concerned I had planned on removing an area of the straight epoxy just around the holes and filling this with some liquid steel or similar to make a higher compressive strength disk which the bolt would go through. So far though I havent felt the need.
Cheers
Mark
