need some help making a servo power supply. I have three servo motors already. I have the print out of each motor. One is different than the other 2 in terms of size and power. How do I figure out what i need? I know I want to have 65V at 20A unregulated power supply. I need to know what toroid transformer to get and from where. I know John at Antek said his 48V @1000VA would do it, but i thought it would have to be 65V? Also I have my cap picked out. It is a Mallory CGS373U075X5L. Here is the links to each of the parts so far.... transformer
http://www.toroid-transformer.com/AN-10248.pdf , and the cap
http://www.newark.com/jsp/displayPro...=CGS373U075X5L
I need to know what rectifiers to get and where also. And last what filter cap.
motor 1 and 2: Terminal Resistance=3.64 ohms, Inductance=5.58mH
motor 3: Resistance of armature at 25 deg. C=0.67ohms, Inductance of armature at 1000hz=0.74mH, Terminal Voltage=85V, Amps at Peak torque=20
I can try to give you more info if needed on the motors
