586,523 active members*
3,299 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > Open Source Boards Available, Stepper Drivers and Break Out Boards
Page 37 of 39 273536373839
Results 721 to 740 of 763
  1. #721
    Oct 2003
    46
    Hi markcomp77 is there a bare pcb available for the bipolar chopper that you listed in post #710? and is 4amp its max amperage?
    Bob
  2. #722
    Jun 2003
    3312
    Try the LM317AVT or keep the supply voltage 35V or less. You can also place a zener diode inplace of r26 to increase a LM317T's 35V by the value of the zener.
    The BZW04-048RL could be eliminated by using a MOSFET whose breakdown voltage is more than double your motor power supply voltage. i.e. if you are using 40V PS a 100V logic level mosfet should be ok.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
  3. #723
    Feb 2005
    130
    Quote Originally Posted by bobleecnc
    no
    I have not make project of pcb for that driver
    Yes... datasheet: L6203 - total RMS current up to 4A
    bridge on ir2113 + 4xMOSFET.... make biger amperage
  4. #724
    1050
    Hi Phil,
    Thanks for the reply, as a mechanical enngineer its hard for me to understand this ' how should i place the zener' , ' What Mosfet would work without the BZW04-48rl can u point out at any'............
    Thanks in Advance
    Irfan
  5. #725
    Jun 2003
    3312
    what power supply voltage are you using?
  6. #726
    1050
    28 V AC step down transformer boiling down to 40 volts DC approx.....havent bought the PS yet so open on that front.
    Regards
    Irfan
  7. #727
    Jun 2003
    3312
    If you can get the LM317AVT that would be the best choice, second would be a 1n3734 or 1n3735 (Zener). Make sure the bar end of the zener is the one that connects to the incomming power supply connection.
  8. #728
    1050
    Hi Phil,
    R u tellin me to use the zener in place of r26? what about the MOSFET let them be the same? U were talking about changing the FETs is that not required?
    Thanks in Advance
    Irfan
  9. #729
    Jun 2003
    3312
    Yes and yes, but if you haven't ordered mosfets use a FQP13N10L or similar 100V logic level mosfet.
  10. #730
    1050
    Hi Phil
    How r U,
    I have got the following, IRFZ44N's, ordered BZW's from mouser and got it already, have taken all half watt resistors including the ones on the optoisolated breakout board(i hope its not a problem) got a 22000 MFD 63v nippon electrlytic capacitor for the PS,
    The motor is rated at 3.35A , one set of winding returs 0.9 ohm and another set 1.5 ohm, i have three motors and all return the same resistance values. Will this be a problem.
    I have calculated the V ref for my motors with R11, 12, 24 in place as 3.35*0.33=1.1055V, u think its correct,
    what shunt resistance should my PS have?
    For the optoisolater ic using H11A817, after studying the motor driver circuit i have come to a conclusion that there are no pull up resistors on the motor driver and i can have the 3.3k pullups on the opto isolator board,
    I have not understood how to connect the EStop to the motor drivers, can u help...
    thanks in advance
    Regards
    Irfan
  11. #731
    Jun 2003
    3312
    Hi contactirfu,
    Me I'm confused....I have a hard time sorting out who has which board and what we have been through. I get questions on various threads, emails, and on my BB. One of the reasons I created my on BB http://www.pminmo.com/phpBB/ was to help me pocket questions about specific boards so when I reviewed the thread, I know going in what the board is going in. Also that others headed down similar paths could review the thread of the board they were interested in. If you would, how about doing a cut and paste of your previous posts to put them together in the right thread on my BB. Would be a big help. Thanks, Phil
  12. #732
    Mar 2004
    1147
    pmino
    you are a pilar of the stepper-driver-needing community.
    i salute you!
  13. #733
    1050
    Meeeeeeeee toooooooo.
  14. #734
    Jun 2003
    3312
    Thanks, I just try to do what I can.... But I have to admit, it's starting to get really confusing. I need to put up a form on my website so I have all the info I need when a user asks questions.
  15. #735
    Aug 2004
    3215
    Quote Originally Posted by pminmo
    I know you have a very very busy schecdule,. I was wondering if you have in works or know anyone who has made their own 60-80v 6a-7a stepper driver? would be interesting for a diy gecko people could play around with and possibly be able to replace their own parts.
    Joe
  16. #736
    Jun 2003
    3312
    Welllllll, I started down a discrete bipolar drive, but in conversation with a semi mfg, found out I just needed to be a little patient.
  17. #737
    Aug 2004
    3215
    Ok, so a better chip will be available soon.
    What chip were you looking at previously, like to do a little research.
    Joe
  18. #738
    Aug 2005
    34
    Can you give us more details?
  19. #739
    Jun 2003
    3312
    I've uploaded a new 5 axis PCB for the DIY'er. http://www.pminmo.com/
  20. #740
    Jan 2007
    10
    HElp please
    This is the Stepper
    http://www.jaycar.co.nz/products_uploaded/YM-2751.pdf
    This Driver With the compatable BOB
    Discrete Driver Boards
    The Stepper is 12v 0.4a 6wire
    the boards work as far as i can tell i have had turbo cnc running and was a ble to use the logic probe to get pulsing from pin3 on IC4 so i am guessing that it is all working i have now installed IRLZ44N in place of the IRF540N that i purchaced at the time. the motor will still not spin
    i wired yellow and blue together
    and red and brown together
    grey and green to +12v
    dose it matter what Wago they go into (x9-1 yellow red ect) i have tryed other combo's with no change. the motor moves if i rub one of the wires on to the -12v. I have no idea what else to try the mosfet's are all working as far as i can tell IC4 pin 1 high Wago X9-1 lo ect as per instructions, +5v working well
    Basicly i would think that if there is a pulsing on the board logic when i move the Axes on the computer it should work maybe there isent enough current somthing like that HELP !! please
    the power supply i am using is 12v 8amp running at about 11.5v 7.5amp
  1. Best break out boards?
    By Nigel Tufnel in forum Stepper Motors / Drives
    Last Post: 12-27-2013, 07:12 PM
  2. Dual Break out boards
    By ynnek in forum DIY CNC Router Table Machines
    Last Post: 07-11-2013, 04:34 PM
  3. Break out boards...
    By kiwichris in forum LinuxCNC (formerly EMC2)
    Last Post: 11-06-2012, 10:20 PM
  4. Servos, drivers, break out boards
    By HereinCS in forum Servo Motors / Drives
    Last Post: 08-13-2010, 06:09 PM
  5. PC parallel port break-out boards
    By widgitmaster in forum CNC Machine Related Electronics
    Last Post: 09-20-2005, 01:47 PM
