586,108 active members*
3,100 visitors online*
    13
    Controller not detected
    I have powered up the controller and then opened up the software. and I get controller not detected. I tried to go in and change the com port and It doesn't reconize the com port, I went in and changed the machine setup for the table size and saved it, still does not see the controller. I have the motors locking and all 3 drives have the red lights on. The control board has the blinking light so it seems that the hardware side is working just no controller. Please HeLPPPPPPP!
    May 2004
    68
    Make sure 2nd Generation controller box is checked in your machine setup. I've also had this happen from trying to use the wrong type of serial cable.
  1. V2XT drive fault detected
    By DF-ENTERPRISES in forum Bridgeport / Hardinge Mills
    Last Post: 03-29-2010, 02:10 AM
  2. O-i controller?
    By Rich 72 in forum Fanuc
    Last Post: 12-04-2007, 07:51 PM
  3. V2XT error message "DRIVE FAULT detected (0,z,y,x) check log"
    By rfdoyle in forum Bridgeport / Hardinge Mills
    Last Post: 10-08-2007, 09:35 PM
  4. DeskCNC 2nd. gen controller AND HobbyCNC Pro Controller
    By maycom in forum DeskCNC Controller Board
    Last Post: 06-02-2007, 07:33 PM
  5. hardeware pause pause detected?????
    By Conquest1224 in forum Commercial CNC Wood Routers
    Last Post: 05-08-2007, 04:06 AM
