586,076 active members*
3,873 visitors online*
Results 1 to 8 of 8
    Jun 2004
    201
    Need help with math
    a 360 turn of the hand wheel on my rotary table is 2.25 degrees of rotation of the table.
    how much of a turn of the hand wheel = 1 degree of table rotation
    Mar 2004
    120
    360 degrees rotation for handwheel = 2.25 degrees rotation for table
    360 degrees / 2.25 = 160 degees
    So 160 degrees rotation for handwheel = 1 degree rotation for table
    embrace enthusiasm to accomplish the task
    Gary Davies... www.durhamrobotics.com
    May 2004
    83
    160 at the handwheel. Odd number though. Most rotary tables are 90:1.
    Jan 2004
    353
    Quote Originally Posted by metlmunchr
    The other common ratio is 40:1.
    270
    Sherline's 4 inch tables are 72:1. Probably the most popular table ever.
    Fred Smith - IMService
    http://www.cadcamcadcam.com
    Jun 2004
    201
    Thats the number.
    Turns into 425 steps in mach2
    4826
    Yes, that 160 turn table would definitely not be classed as a user friendly rotary table for manual use!
    First you get good, then you get fast. Then grouchiness sets in.
    May 2004
    83
    Hu, everyone knows true "user friendly" dividing devices have motors attached to them. Motors help prevent so much of our blood from draining out thru our knuckles
  1. units per inch math
    By gearcut in forum Mechanical Calculations/Engineering Design
    Last Post: 05-29-2005, 07:02 PM
  2. Need some math help...
    By kanankeban in forum Mechanical Calculations/Engineering Design
    Last Post: 04-03-2005, 09:27 AM
  3. math needed to build a cnc
    By trubleshtr in forum Mechanical Calculations/Engineering Design
    Last Post: 03-16-2005, 08:20 PM
  4. Motor math...am I doing this right?
    By WoodSnarfer in forum Servo Motors / Drives
    Last Post: 11-22-2004, 01:13 PM
  5. Timing Belts Math...Help!
    By kanankeban in forum DIY CNC Router Table Machines
    Last Post: 11-02-2004, 04:19 AM
