586,609 active members*
3,396 visitors online*
    Feb 2008
    263
    Trim Router on/off control?
    I will be buying the 3-Axis ProboStep Stepper Motor Driver Kit. Is it possible to have the kit control the trim router using a relay board?
    You'll need to use their relay board, and probably the breakout board.
    Feb 2008
    263
    I looked at the wiring diagram for the relay board and I'm not sure about connecting the router motor to the relay board. The breakout board comes with the kit. The relays are rated for 12 Amps at 125 VAC. The Dewalt trim router uses 5.6 Amps when running but what about the power needed to start the router running?
    May 2007
    380
    You can use the driver board relay to control a heavier external relay. Just find one with a 120 volt coil.
    John
  1. 3-D revolve trim
    By youngfg in forum BobCad-Cam
    Last Post: 02-07-2008, 05:07 PM
  2. Trim
    By john_mccarron in forum EdgeCam
    Last Post: 11-28-2007, 01:42 AM
  3. HF Trim Router-Price/Coupons?
    By Rance in forum DIY CNC Router Table Machines
    Last Post: 09-05-2007, 07:27 PM
  4. Trim Toolpath
    By camtd in forum EdgeCam
    Last Post: 10-20-2006, 06:00 AM
  5. Trim and extend?
    By tinman13 in forum BobCad-Cam
    Last Post: 03-30-2006, 05:11 PM
