I just got the C11G BOB and I'm not sure on some of the connections. I plan to use an E-Stop but I'm not sure if it needs to be between pin 10-5v or if I should use the 5v-EN & Pin 10 on the input?? I also want to use my one of limits on X,Y & Z as my home input. Can the C11G do that or do I have to have seperate switches for home. I know I can set it up in Mach 3, just not sure about the BOB.
I think the BOB requires 12vdc and 5vdc. I plan to use to wall warts for that and I see where the 12vdc/gnd connects but do both dc supplies have to share a gnd? I see several spots for the 5v/gnd to connect, I just don't want to let the smoke out!!!
I think the 203v will connect to Step, Dir & Common on the output terminals. I've selected a small jumper that says 2-3... comm=gnd on the BOB. Is that correct?
I plan on using the saftey charge pump thats built in so the jumper is on 2-3 and I will assign pin 17 to it from Mach.
If anyone out there has this combination please tell me if I'm on the right track.
Dan
