586,822 active members*
3,379 visitors online*
Results 1 to 8 of 8
    Feb 2007
    26
    My parts list - would like opinion
    Can someone let me know if I am picking good parts to build my first machine with.
    1 LMC16 x 650mm rail bearing shaft XYZ table CNC router (Y Axis)
    1 LMC16 x 4 pc linear ball bearing XYZ table CNC router (Y Axis)
    2 24" 1/2-10 ACME Lead Screw w/ Delrin Nut for CNC Router(Y and X Axis)
    1 12" 1/2-10 ACME Lead Screw w/ Delrin Nut for CNC Router(Z Axis)
    2 3/4" Round Precision Ground Rod 24" (X Axis)
    1 1/2" Round Precision Ground Rod 24" (2 x 12") (Z Axis)
    2 SC20UU x 4 pc linear ball bearing (X and Z Axis)
    1 3/4" 4'x8' MDF
    1 G540 4 axis controller (when it comes out)
    3 282oz-in stepper motor 2 phase
    I am looking for opinions
    Haku
    Use 1/2-8 2 start or 1/2-10 5 start acme.
    Feb 2007
    26
    What is the difference??
    Haku
    You'll get 3-5 times more speed than with single start 1/2-10.
    Feb 2007
    26
    I mean what is the physical difference, a different pitch??
    Haku
    Jan 2008
    7
    I'm still learning this stuff as well so you might want to wait for someone to confirm but this is my take on it.
    You can think of each start as a separate spiral running the length of the rod. A 1 start has a single spiral groove like a normal screw. A 2 start has 2 spirals, like a double helix, so you you would get an effective 4 tpi out of a 1/2-8 2 start or .25 inches per revolution. A 1/2-10 5 start would give an effective 2 tpi so for every turn of the screw you would move .5 inches.
    Yes, 1/2-8 2 start is 4 turns per inch. 1/2-10 5 start is 2 turns per inch.
    Sep 2007
    740
    Plus higher efficiency. Multi-start screws are usually higher efficiency than single. Some of the motion screw manufacturers publish information about there screws.
    Look here.
    http://nookindustries.com/acme/AcmeAvailability.cfm
  1. A little lost... How does this X2 conversion parts list look?
    By JMcDonald in forum Benchtop Machines
    Last Post: 05-27-2007, 01:04 PM
  2. Fanuc 10 parts list needed
    By curtisturner in forum Fanuc
    Last Post: 09-23-2006, 05:36 PM
  3. You opinion on my plan? Updated: DXF and Pics of parts included
    By Darren in forum DIY CNC Router Table Machines
    Last Post: 08-31-2005, 02:44 PM
  4. Haas parts list
    By rattlesnake363 in forum Haas Mills
    Last Post: 08-11-2005, 03:38 AM
  5. parts list for new shop (did I miss anything?)
    By blazer928 in forum Uncategorised MetalWorking Machines
    Last Post: 04-13-2005, 06:09 PM
