586,060 active members*
3,380 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Table length cutting problem?
    Sep 2006
    36
    I have a 14"x24" machine. I would like to know how to cut something longer than 24"
    THX
    Cut 24", then move the part and cut some more. Usually you'll want to use some type of fence to keep it aligned, or drill holes and use pins or dowels for alignment.
    Apr 2007
    40
    Check This Video
    Dave
    "updates always change the feature you need most. "
    Jun 2005
    90
    Pretty good video dshowalt. Very generous to record the sequences.
    That's pretty much the way I handle this as well; fence to slide accurately (generally machined with the CNC tool), registering marks (or dowel pins for maximum accuracy) and a good set of toolpaths according to the specifications.
    It can get more complicate but that's the basic of handling longer projects than the machine bed can.
    My business Web site - USINUM - www.cooptel.qc.ca/~usinum
    My BLOG at Blogger - http://pacosarea.blogspot.com/
    Apr 2007
    40
    Re Video
    Not my video, I just remembered seeing it a while back and thought it could help.
    Dave
  1. My CNC Plasma Cutting Table
    By DZstar in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 09-12-2014, 07:20 AM
  2. New O/A Cutting Table
    By whateg01 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 05-31-2013, 07:30 AM
  3. glass cutting table
    By cristian gabor in forum Mechanical Calculations/Engineering Design
    Last Post: 05-29-2009, 07:51 AM
  4. Can I mill a 6ft length of box steel on a 4ft milling table?
    By Apples in forum MetalWork Discussion
    Last Post: 03-02-2008, 05:39 AM
  5. Cutting table : inquiry
    By smartcut in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-20-2006, 06:58 AM
