586,051 active members*
3,751 visitors online*
    Feb 2006
    52
    Joint following error
    help..
    acquired a laptop with more mem and speed and setup emc on this all seemed ok untill i started doing some long rapids and system sets error and looses steps. have double checked latency approx 14000. the rest of the system less the laptop was running fine on old 450mhz desktop prior to swap.
    getting joint follow errors when rapiding for any distance. I have changed vel. and acc. in stepconfig.ini played with latency nothing.
    can these settings be changed globaly in my ini file or run stepconfig.
    I ask because rapids dont sound the same as what i get when testing in the stepconfig wizard. system runs everything program wise.
    stepper system
    ubuntu 6.06
    emc 2.2.3
    Thanks gads
    Feb 2007
    514
    Laptops are not for real time...
    John
    Apr 2004
    40
    Quote Originally Posted by Big John T View Post
    Yeah probably, but... If the latency is 14000, does it matter that it's a laptop? That's a direct measurement of just how real-time it is.
    Assuming you're using a parallel port, does your laptop have a weaker voltage on the pins? Maybe with a weaker signal the motor driver inputs are picking up more noise when the motors are moving quickly.
    Just a wild guess to check the electrical side of things.
    Feb 2007
    514
    Quote Originally Posted by Ryobiguy View Post
    The problem with laptops is not the latency it's the nasty habit they have of shutting down and interrupting the processing which gives you missed steps etc...
    John
  1. How do I cut carbon fiber (Joint Strike Fighter)?
    By vettespeed in forum Composites, Exotic Metals etc
    Last Post: 06-26-2010, 09:59 AM
  2. joint venture in China
    By JennyYin in forum News Announcements
    Last Post: 11-06-2006, 09:21 AM
  3. slip-ring, electric swivel / rotary joint
    By DrStein99 in forum Mechanical Calculations/Engineering Design
    Last Post: 08-10-2006, 01:39 AM
  4. help with screw joint in cosmosmotion
    By posix in forum Solidworks
    Last Post: 01-17-2006, 12:40 PM
  5. Intersting robotic joint
    By Zathras in forum Mechanical Calculations/Engineering Design
    Last Post: 10-07-2005, 07:05 PM
