586,065 active members*
4,340 visitors online*
Results 1 to 9 of 9
    Jun 2006
    170
    y axis disconnect alarm
    been having a problem with y axis disconnect on a fanuc o-m controller. It is a problem that has been happening for a while. I have been doing the p-cancel button on power up. But today it took about a dozen tries to get it to zero return.
    Once i ran a program the first time it worked fine. The second time it seemes like it lost all idea where it is in the y axis. Nothing i try now seems to work. I shut the machine downand re-zeroed, but all that happens is a random tool path.
    Any ideas? Thanks
    Jun 2007
    43
    disconnect
    Sounds like you have a wire break, probably in the drag link, on your encoder cable. The other possibility is coolant in the motorplug, if that is possible on your machine. Best bet is to put on a new cable. As it is an 0M, nothing special, probably half a dozen twisted pair at max.
    Nine times out of ten, visual check, and continuity check, will show cable ok. Sometimes you can feel a "lump". For what it is worth, intermittent problem like this, remake the cable.
    Outside possibility of the power cable to the motor.
    Jun 2006
    170
    thanks...i will check that in the morning. I wish i would have keep track of whether i used coolant the day before a problem all along, but i know i did yesterday. I don't always need coolant ,as i cut a lot of plastics.
    last time i tried the machine before i went home today i am almost sure it zero returned out about .25" from where it should have even though the light came on. When i tried the program it was zig zaging back and forth like it was trying to find its way out of a maze. It just does know where it is ,where it come from , or where its going.
    Jun 2006
    170
    I should also mention it is a Kiwa/Excel vmc, made in '91. Not sure if it makes a difference or not but any info might help solve it.
    Jun 2006
    170
    Quote Originally Posted by GEM View Post
    The motor plug was damp. Ater drying it out and cleaning it up I still had the same problem. Is there by any chance something i needed to do besides cancel-p to reset the machine. I am about to take the cable out so i would hate to go through it only to find out i missed something simple.
    Jan 2006
    121
    Hello
    Please check the troubleshooting information here.
    http://www.kfasllc.com/F0_troubleshoot.htm
    Let me know if you have any questions. Good luck.
    Jun 2006
    170
    removed the cable an did a continuity check and everything was fine. We couldn't find anyone who could or would make us up a cable. Some figured it was a propitary(sorry about the spelling on that) issue or a conflict with Fanuc so they wouldn't do it.
    To make a long story short i put the cable back in and it worked. So it is either fixed or Monday morning i take the cable back out...
    24221
    We always make our own cables up when installing systems.
    Haven't found anything proprietary yet.
    Al.
    Albert E.
    Jan 2006
    121
    Please check with http://www.fanuccables.com/. they should be able to help you.
  1. Replies: 6
    Last Post: 04-29-2011, 11:20 PM
  2. Tachogenerator disconnect alarm on 10T
    By Crashmaster in forum Fanuc
    Last Post: 10-09-2007, 09:35 PM
  3. Need disconnect for powerfeed
    By Chevy-SS in forum Benchtop Machines
    Last Post: 04-09-2007, 04:27 PM
  4. Fanuc 21-GA_416 Alarm-Axis Disconnect
    By lasermike in forum DNC Problems and Solutions
    Last Post: 03-10-2005, 07:49 AM
