586,096 active members*
3,012 visitors online*
Thread: Charly Robot
Results 1 to 8 of 8
    Dec 2007
    Charly Robot
    Anyone know anything about the Charly Robot machines? It seems interesting and a step up from the Roland Stuff. I am considering a Taig build out, but this machine is all ready to go with an enclosure with lubrication.
    Charly 4U
    http://www.charlyusa.com/2-Products/...U/Charly4U.htm
    180
    They look pretty trick. Any idea of pricing?
    Mar 2008
    201
    Looks like they are designed for high speed machining in really soft materials like clay or plastics, some light aluminum milling as well. There was a small aluminum mould being milled in the Charly2U videos and both machines appear to be contructed the same way.
    So for stuff like milling PCB's, clay prototypes or small aluminum moulds they would work great. High speed spindle and ballscrews stock.
    For heavier aluminum milling the Taig would be a better choice IMO.
    180
    Quote Originally Posted by sergizmo View Post
    Is there any way to increase the XY travels on the Taig. It's a great little machine, but pretty limiting in work envelope.
    Mar 2008
    201
    Taig offers the option of 12" of X travel (longer bed) as opposed to the stock 9.5". There is no way to increase Y, so 5.5" is the max.
    What kind of parts are you doing that you need more than 12 by 5.5?
    180
    Circuit boards, I could use a little larger work envelope. Guitar inlays.
    I'd like to get a 4th axis so a Taig still looks intriguing.
    Mar 2008
    201
    If you are working with guitar inlays and PCB's the Charly may be a better choice. Larger work envelope and faster travels, and these materials don't need a really stiff machine.
    The Taig is better suited to aluminum removal though, as it is more rigid and has more powerful steppers (200oz/in vs 128oz/in).
    So you have one machine that is reasonably stiff for it's size and can mount a 4th axis. Then you have one that has larger travels and is faster.
    May 2010
    Exclamation Does anyone knows a machine like the charly2u but less expensive?
    Does anyone knows a machine like the charly2u but less expensive??? Im interested in one of those in an A2 format, but the charlyrobot costs like 20K. I need one with an enclosed work area like that cuz i have breathing problems.
    thanks!
  1. What robot?
    By ToyMaker in forum RC Robotics and Autonomous Robots
    Last Post: 12-07-2012, 07:14 AM
  2. Robot Arm controller
    By holymegabyte in forum Controller Cards
    Last Post: 04-07-2012, 07:14 AM
  3. CRS Robot Arm
    By pestana1957 in forum RC Robotics and Autonomous Robots
    Last Post: 01-26-2007, 09:04 PM
  4. CNC to Robot
    By GT_racing in forum G-Code Programing
    Last Post: 05-24-2006, 02:18 PM
  5. robot arm help
    By magicruss in forum RC Robotics and Autonomous Robots
    Last Post: 03-02-2005, 06:06 AM
