586,100 active members*
2,604 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > current per phase for power supply?
    Jul 2004
    148
    driver When designing a power supply, is one to look at phase current or rated current of stepper motor? ex. 2 phase motor rated at 5v 3amps. Lets say a three axis machine. Would I design my power supply for 3amps x 3=9amps or would it be 3amps x 2phase=6amps x 3 motors= 18 amps.I understand that depending on the driver I use will make a difference on the percentage of amps to use in the calc., something like 67% of total amps(ex. a chopper drive). What about without a chopper drive, should I go with the total amps + 20% to cover all bases? I seem to be using a basic bipolar drive. The one on electrokits.com
    With that drive, yes, add up all the amps for each phase. 3a/phase times 2 phases/motor = 6 amps times 3 motors = 18 amps. I'd maket it at least 20.
    If you used Gecko's, on the other hand, you'd only need about 6 amps. You'll be wasting a LOT of power through your resistors.
    Jul 2004
    148
    ALSO, What is the amp rating refering to on most stepper motors(per phase amps or total amps)?
    per phase
  1. Staggering motors
    By viktorcnc in forum Stepper Motors / Drives
    Last Post: 10-25-2015, 08:11 PM
  2. How does a power supply work.
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 07-27-2011, 03:40 PM
  3. Need more power
    By mvaughn in forum CNC Machine Related Electronics
    Last Post: 06-15-2005, 12:11 PM
  4. Series Bipolar and parrallel bipolar?
    By cncadmin in forum FAQ of DIY CNC Machine Building
    Last Post: 09-08-2004, 01:17 PM
  5. Egads! 3 Phase power supply?
    By samualt in forum CNC Machine Related Electronics
    Last Post: 10-03-2003, 02:37 AM
