586,096 active members*
3,378 visitors online*
    Jan 2007
    311
    Drain Pre-screen
    I've got a bit of this screen laying around and after spending way too long picking curled stainless chips out of the fine mesh by hand, I added this pre-screen to the drain to catch the larger chips before they make it to the fine screen.
    I don't even remember where I got this stuff but I do know that I've seen it on air-filters used for transport trucks. A trip to the local service yard may net you a used filter to scavenge
    It's just a little oversize on the length so that it "springs" into place.
    Time will tell if it was worth the effort
    Mooser
    Feb 2006
    1072
    The perf metal looks like a worthy addition, Mooser. I should add a piece on the extra drain I drilled on the left-hand end of the table.
    On my own screen, I added a piece of coarse welded steel wire mesh under the fine fabric to support it, and that makes it a lot easier to vacuum and/or scrape chips off.
    Randy
  1. Homemade Screen Printer/Silk Screen
    By Sbthomas13 in forum Machine Created Art
    Last Post: 02-14-2009, 01:35 AM
  2. Replies: 4
    Last Post: 03-11-2008, 07:43 PM
  3. DVD - DRO Screen
    By skip20 in forum Mini Lathe
    Last Post: 03-06-2008, 09:09 PM
  4. SL-10 Coolant Drain Upgrade
    By Edster in forum Haas Lathes
    Last Post: 01-20-2008, 05:01 PM
  5. SL-20 big screen ?
    By Jones_69 in forum Haas Lathes
    Last Post: 09-01-2007, 01:12 PM
