I am doing rigid tapping for the first time on Haas Mini Mill
Material: Aluminum 6061-T6
Tap size: #10-32
Tap: HSS Spiral Flute Tap (Greenfield)
Full thread depth required: 0.5”
It is a blind hole drilled to 1.2” depth
I tried with 500 rpm (Too low I presume). The chips get entangled in the tap and are not thrown away by the coolant. I tried going 0.25” full thread depth only.
What is the recommended rpm for this tap size?
By using higher rpm and increasing the R plane value from .1 to .4 will help?
Can I go the depth of 0.75” in one shot? (this will give the full thread depth of 0.5”)
R. Rossey
