586,670 active members*
3,258 visitors online*
    Mar 2004
    4
    gas pipe or hot/cold water pipe?
    Hello everyone,
    I am slowly getting parts together for my first JGRO Router. The local home depot has gas pipe that is painted black or hot/cold water pipe that has no paint on it. looks like a better surface. Would it be ok to use the hot/cold water pipes?
    Jul 2003
    196
    Water pipe probably has been galvanized. Over time it will start to flake off. Most people use the gas pipe and sand/polish the paint off of it.
    jgro
    Feb 2007
    26
    What about the quality of pipe. If I bought some galvanized pipe and took a small amount off with a lathe, would that suffice??
    Haku
  1. Instead of Gas Pipe
    By Bartsimsonii in forum Commercial CNC Wood Routers
    Last Post: 11-19-2007, 03:39 PM
  2. pipe tap
    By toolendmill in forum BobCad-Cam
    Last Post: 06-26-2007, 06:52 PM
  3. emt conduit, galvanized pipe or black pipe?
    By JohnG in forum DIY CNC Router Table Machines
    Last Post: 05-22-2006, 02:24 AM
  4. Using Pipe
    By rockom in forum DIY CNC Router Table Machines
    Last Post: 10-17-2005, 12:07 AM
  5. final pipe
    By D5zUga in forum Rhino 3D
    Last Post: 10-20-2004, 10:13 PM
