586,100 active members*
2,906 visitors online*
Page 1 of 3 123
Results 1 to 20 of 53
    Oct 2007
    40
    JGRO in basement (upstate NY)
    All,
    I have started a build on a JGRO design in my basement. I am using more or less the JGRO plans with minor modifications. I have attached three pictures.
    One of the progress so far. I have cut my linear bearings using a metal blade in the sawsall with the vice holding the angle. I then filed the burrs. I cut a few of the MDF pieces also.
    I also attached a picture of the casters and the cut pipe. This is an innovation as suggested to me by a pal of mine. The plan is to use these as my pipe aligners for the y axis at least. So the caster goes on the y supports and the threaded 1.75'' pipe threads into the caster. The hardware store that is orange cut and threaded them for me! The pipe is tapped to fit the bolts, and the 1'' y axis fits inside the pipes. We'll see how it works. It is heavier, but I bet a lot sturdier than MDF or plastic.
    I added a picture of the modest tools I am using.
    1. Cheap Router and table. Not sure if I want to use the router for my spindle
    2. Aluminum straight edge - very useful for guiding the cheap circular saw
    3. Drill press I got from Big Lots for $50
    4. Sawsall
    5. Vice
    6. Shop-Vac, maybe I can use this as a dust collector later
    7. My old high torque hammer drill - I have gotten a ton of use out of this thing
    I have ordered my bearings from a seller on ebay:
    608-2RS Inline Skate, skateboard bearings, ABEC 7. They came to $21. Seemed fair.
    I plan on using 1/2 10 single start lead screws from ENCO unless someone has a better suggestion. These seem like a good price and I have read on this community that they work well enough.
    http://www.use-enco.com/CGI/INSRIT?PMAKA=408-0220
    I am planning on using couplers and anti-backlash nuts from dumpsterCNC. Unless anyone has strong feelings otherwise.
    http://www.dumpstercnc.com/
    And I plan on a 305 oz-in kit from hobbycnc.
    I haven't figured out where to get the other items required such as flange bearings. Maybe mcmastercarr?
    As usual any help or advice would be appreciated. Good Luck!
    ElSeed.
    Attached Thumbnails Attached Thumbnails Tools1.JPG   Progress.JPG   Innovation.JPG
    ElSeed
    Dec 2006
    775
    I would suggest the 1/2 10 5 start. I have the 1/2 8 2 start on my current JGRO. it works much better then the single start you mention above. I'm building the 4x4 Hybrid, and on it, I'm planning the 5 start as Joecnc2006 suggests in his design.
    http://www.mcmaster.com/
    Part No. 99030A7041018 Carbon Steel Precision Acme Threaded Rod 1/2"-10 Acme Size, 2 Turns/Inch, 6'L, Rh ThreadIn stock at $55.77 Each
    Increasing the starts will increase your low rpm top speed. Stepper motor's max power is at low RPMs.
    You can get flange bearings from this place.
    http://www.thebigbearingstore.com/servlet/the-68/1-fdsh-2%22-Four-Bolt-Flange/Detail?sfs=47e19780
    It should work on both the X and Y axis for sure.
    Oct 2007
    40
    Glidergider,
    Thanks for the information. I think that I will definitely use some upgraded screws for my next machine. This one I am trying to build cheaply to get my feet wet. But I really appreciate the information. I did not know that steppers give max power at low rpms.
    Those flange bearings look great, thanks.
    Elseed
    ElSeed
    Oct 2007
    40
    Bearings are here
    Got my bearings today. I should have my linear bearings done this week!
    ElSeed
    ElSeed
    Dec 2006
    775
    Elseed,
    I know exactly where you are, building a JGRO. I was there too. It's a neat place to be. I hope you have half as much fun as I've had with mine.
    Quote Originally Posted by elseed View Post
    Glidergider,
    Elseed
    Feb 2007
    75
    Did you get your bearings from a seller named Nextridge? I just ordered some bearings from him on Ebay and the price was very close to what I paid...
    My Website and Buildlogs - www.myhomecnc.info
    Oct 2007
    40
    no, I got mine from bobhill5 on Ebay. He got them to me quickly.
    They seem fine.
    I made one linear bearing this last weekend. Man it takes time. I had some trouble getting the holes in the right place, I used my drill press.
    And then I used a flat carbide bit on the drill press to try to route out the notch for the attaching bolt. I figured I could put the angle flat on my clamp and then slowly work it into the spinning bit.
    It worked. But I can't help but think this was a rather hard way to do it.
    ElSeed
    Feb 2007
    75
    I assume you are using steel angle...
    The way I did it was to drill my pilot holes in the appropriate places with my drill press, then I chucked the tap into the drill press and got the angle and table as close to the tap as possible before lowering the bit. Open the top of the drill press and disconnect the drive belt from the pulleys. Now with one hand press down on the lever to lower the bit and get it touching the hole in the workpiece. With the other hand, turn the pulley that drives the chuck. This ensured that I got perpendicular tapped holes every time.
    Also, be sure to use some sort of cutting oil to ease with the tapping process. I used some WD40 and it worked fine.
    Oct 2007
    40
    Electronics working!
    I am not dead. I had to put the old jgro project on hold for a while because I almost moved.
    Anyhow, I didn't. And it is time to start up the project again.
    I have done some hardware work, but this weekend I got my electronics working.
    I have an old dell that I am going to use Ubuntu 8.04 with EMC2. I am also using the 305 oz-in package from hobbycnc.com with the EZ driver board.
    I had to:
    1. Install Ubuntu 8.04 (after installing 8.06 and then realizing that EMC2 doesn't work with that yet)
    2. Put the board together. Soldering the PCB kit wasn't too hard. I did screw up one of the jumpers by accidentally soldering over the hole without a solder sucker handy. After a while I managed to get the jumper in.
    3. Install EMC2
    4. Modify an ATX power supply to power it as described on hobbycnc.com
    5. test
    I do not know what the right configuration is for this setup for EMC2, so I am using the step time and space of the default for EMC of 2000 ns.
    My jitter is set to 15000 ns.
    Does anyone else have the 305 oz-in motors with the hobbycnc EZ board?
    Anyhow, it is shockingly working!
    More soon, I promise.
    Elseed
    ElSeed
    Nov 2008
    Where abouts in upstate Ny are you located? I am in horseheads.
    Oct 2007
    40
    capital district
    ElSeed
    Oct 2007
    40
    I ordered my stuff from dumpstercnc today. Pricey, but I figure it would take me a long time to reproduce this stuff with the tools I have.
    3 couplers - 1/2 10 for the enco leadscrews and 1/4 bore of the 305 hobbycnc motors
    3 anti-backlash nuts for the 1/2 10 enco leadscrews.
    I will let you know how they work out.
    ElSeed
    Dec 2006
    775
    Good to see you are making progress.
    May 2009
    264
    Does it matter for the anti-backlash nuts if your lead is 1, 2 or 5 start?
    I'm looking at some ACME 1/2-10 lead screws from Keystone but ENCO doesn't list what start it is....
    Sep 2007
    740
    YES
    The nut must match the screw. If its not listed I would guess single start, but thats a guess. If you can't find the information, call them and ask.
    Dec 2007
    28
    The Enco ACME screws are single start. I have them. The nuts have to match the screws.
    I just finished my JGRO (Long Island)
    Oct 2007
    40
    dumpstercnc lists the enco part number for the leadnuts. Enco [part# 408-0200]
    I got the longer section for only slightly more.
    elseed
    ElSeed
    Oct 2007
    40
    annoyed at not having a cnc to help build my cnc
    Man I wish I could have a machine cut my parts for me . Everything is a struggle. I have to make the bearing mounts soon, so I got a special 1 and 1/8 bit. Can't wait to try making these pieces out of mdf with my chop saw and drill press .
    What a pain . I attached a picture of the dumpster stuff plus some odds and ends. The dumpstercnc stuff looks fine, although, one of the screws is a different head size that the others?
    Elseed
    ElSeed
    Oct 2007
    40
    video of the steppers turning
    I thought you might like to see a video of ubuntu 8.04 turning the hobbycnc 305's with the EZ board :wave:.
    [ame="http://www.youtube.com/watch?v=qgX3Je8f9Qo"]YouTube - stepper driven by EMC2 and Ubuntu 8.04[/ame]
    Elseed
    ElSeed
    Oct 2007
    40
    Quote Originally Posted by Glidergider View Post
    Thanks. It has been a long slow ride so far. Hopefully the project will come to fruition and then I can make a much better machine easier.
    ElSeed
Page 1 of 3 123
  1. VMC in basement?
    By XXF in forum Haas Mills
    Last Post: 02-15-2012, 02:54 PM
  2. UPSTATE New York/Penn.....? MACH III cnc'ers
    By kmcwhq in forum Mentors & Apprentice Locator
    Last Post: 10-19-2008, 04:05 AM
  3. Bobcat in the basement
    By metalbyter in forum Community Club House
    Last Post: 02-28-2008, 08:32 PM
  4. Mentor in Upstate NY, Capitol District???
    By victorf in forum Mentors & Apprentice Locator
    Last Post: 12-16-2006, 11:54 PM
  5. Basement Workshop
    By Hack in forum Community Club House
    Last Post: 01-13-2006, 03:26 PM
