586,112 active members*
3,005 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Comments Needed-Wood vs. Metal in Garage shop
    Mar 2005
    10
    I would like to build a CNC router and have looked at several designs and read many of the threads regarding DIY machines (Solsylva, Joe's 2006, Pilot Pro). Whatever machine I choose will be built and used in my garage (I live in Utah outside of Salt Lake City). The garage has no heat or cooling. It's relatively dry here, but there would be huge temperature swings. After investing the time and money to build one I would want it to last and keep it's tolerance. So what would you use, wood or metal?
    Steve
    Dec 2007
    617
    I'd recommend using steel, provided that you have the skills and tools available to weld, and or machine. From a strength and resistance to distorsion/time standpoint steel would be my choice. I'd not be too concerned with the temperature swings, as long as the temperature doesn't radically change during machining. Depends on what you are building...precision cabinets, or hobby stuff.
    regards
  1. Wood or metal
    By cncman2 in forum DIY CNC Router Table Machines
    Last Post: 08-04-2013, 04:29 AM
  2. SE Michigan garage shop
    By choppersprocket in forum Mentors & Apprentice Locator
    Last Post: 07-11-2007, 07:40 PM
  3. Detached Garage Shop - CNC Choice
    By hflwaterski in forum DIY CNC Router Table Machines
    Last Post: 11-30-2006, 07:32 PM
  4. Comments and help needed
    By marcusb in forum Stepper Motors / Drives
    Last Post: 06-12-2006, 10:56 PM
  5. Comments needed for this design...thx!
    By andyew in forum DIY CNC Router Table Machines
    Last Post: 08-31-2004, 09:59 PM
