586,052 active members*
4,287 visitors online*
Thread: Lost Steps?
Results 1 to 12 of 12
    Feb 2007
    75
    Lost Steps?
    Hello...
    I'm using Mach 3 with a HobbyCNC 3-axis board, and I'm having trouble with arbitrary loss of steps...
    This has happened several times now, usually on the Y or X axes... For instance, today I was milling polystyrene foam wings, at ~150 IPM... Light cuts, 0.005" per pass... I had cut a pair of wing beds and a wing, no problem... I go to cut the other wing, and it was about 50% finished when the X-axis suddenly lost ~1", and destroyed the part. I canceled the job, and returned the axes to home, and sure enough, the home point had moved by ~1" in the X-direction.
    I checked the mechanical systems (it's a DIY mill, so sometimes things slip), but everything was in order. I was sitting right there, watching it run, so I know that it didn't stall on anything, either. Also, at 150 IPM, the steppers aren't being pushed too hard, the machine can jog (or rough-cut foam) at 350 IPM without skipping.
    Any suggestions, at least as to where I should start trouble-shooting? Could this be caused by a dirty power supply? For what it's worth, I'm running a shopvac and the 'spindle' (a Hitachi router) off the same circuit as the computer and stepper controller, and I've been meaning to get a surge protector for about two months now...
    ~Luke
    Apr 2006
    3498
    check ur lead screw at the location for any wear/tear or dust...
    Feb 2007
    75
    Well, I'm running timing belts on everything except the Z-axis... However, they're clean and well-tensioned, and the bearings are running freely... It only occurs very sporadically, and I can never reproduce it, but it's quite annoying when it happens...
    ~Luke
    Feb 2007
    75
    Ooh, by the way, the computer I'm running MACH 3 on has a 1.8 GHz processor, with 256 MB of RAM, running XP. I guess the RAM is a bit under spec., eh?
    ~Luke
    Apr 2006
    3498
    Hmmm... When u run Mach3, avoid working on any other program. Stop internet, stop media player, every thing... except Mach3
    Mar 2005
    59
    Did you use FeedOverRide ?
    Juka
    Jun 2004
    i am just starting to use my router running mach 3 and having the same problem would be pleased to find a cure
    Feb 2007
    75
    I used speed override a couple times, and it ended WAY off... 6"+ on the Y-axis. Now I leave it alone.
    Thanks for the pointer on other programs. Would that include screen saver? Also, should I keep the computer from going into any sort of power-save mode?
    ~Luke
    Quote Originally Posted by IAD View Post
    ~Luke
    Yes, and yes. ANY other programs running can cause problems. Especially the ones that run in the background that you don't see.
    Aug 2007
    215
    you could also try lowering your acceleration settings.
    Power suppy is a good start, dediaction for power supply may not ever fix problem, if you a lot of inductive loads in your shop this cause's spike's or fluctuations on all branch curcuits. segrigate to seperate curcuit's, try surge protection filtration second. I dont know what else... have fun.
    Feb 2007
    75
    Well, I switched to LinuxEMC, and that helped a lot. Then I disabled idle current reduction, which basically puts the controllers into sleep mode, if they haven't been moved within the past minute or so... (Coming out of sleep mode can take a fraction of a second, during which steps can be lost.) That seems to have helped, too.
    Now I'm only having intermittent problems with the Z-axis, it's still skipping, sometimes as much as an inch. I can actually hear the motor go into 'runaway'; today I'm going to try loosening the bearings a hair, see if that helps.
    ~Luke
  1. Lost steps and stalling
    By CAM_MAN in forum Stepper Motors / Drives
    Last Post: 04-12-2006, 06:34 PM
  2. Questions on lost steps.
    By southernexplore in forum DIY CNC Router Table Machines
    Last Post: 03-05-2006, 02:10 AM
  3. Engraving and lost steps...
    By Parameter in forum Stepper Motors / Drives
    Last Post: 12-12-2005, 07:06 AM
  4. Lost Steps
    By boxwood in forum DNC Problems and Solutions
    Last Post: 07-09-2005, 03:26 PM
  5. help with lost steps??
    By chrisw765 in forum Xylotex
    Last Post: 06-16-2005, 09:59 PM
