586,100 active members*
2,713 visitors online*
    Jan 2008
    11
    Breakout board - power light indicator?
    Hi, all,
    My 4030 kit just arrived on Friday, and I finally got a chance to start hooking things up this evening. Most of it went great, but I had a question - on the breakout board, next to the inputs from the 5V DC adaptor, there is an LED labelled "power". When I turn everything on, though, this light stays out.
    Now, I haven't tried hooking this up to my PC yet, as I'm slightly paranoid about that LED not coming on. Is this normal?
    (And just to verify - with the DC adaptor, the wire with the white dashes is the ground, correct?)
    Thanks for any insight!
    Jan 2008
    11
    Finally got a chance to get back to this with my voltmeter, and it looks like I was wrong - white dashed stripe was the positive wire, contrary to some other posts I'd seen! The voltmeter says it's putting off around 6.5 V, so once I attached the leads correctly, all was well and my little power light lit up like a star.
    Which reminds me - I thought it was supposed to be a 5V power supply, not a 6.5. Will this cause trouble, or is it just an updated model?
    Apr 2007
    34
    Hi my power supply is rated at 6V, i dont remember the actual output, I don't have the motors on the machine yet, but they spin just fine sitting on my desk so i think you are ok. I recieved my kit only a few weeks ago so its most likely the same power supply.
    Cheers, Dave
    Jan 2008
    11
    Thanks for the confirmation - I hooked everything up, and my motors are spinning nicely as well.
    Happy building!
  1. what USB Breakout Board to by ??
    By dbss in forum CNC Machine Related Electronics
    Last Post: 01-19-2008, 02:54 PM
  2. Breakout board, Relays on board?
    By Cooper in forum Open Source Controller Boards
    Last Post: 06-10-2007, 01:55 AM
  3. New breakout board
    By corydoras in forum CNC Machine Related Electronics
    Last Post: 04-26-2007, 12:23 AM
  4. Best breakout board?
    By nate in forum Xylotex
    Last Post: 01-03-2007, 02:39 PM
  5. What is a breakout board?
    By andy_ck87028 in forum Stepper Motors / Drives
    Last Post: 08-28-2005, 11:37 PM
