I have a Bridgeport Interact 308 w/TNC2500. I have a problem with the control powering up. It has always been a little slow but recently has got much worse. Once you power the machine the CRT and boot up dont happen right away. In the past you could let it set powered for a few min and it would go ahead and startand boot. Now it takes as much as 2 hours. Once its up it runs fine. I can turn off the machine and power it right back up with no problem but If I wait 5 min the process starts all over. It was suggested that I go through and start replacing caps 1 at a time but Im a bit reluctant to just go after it. Would rather do some research and ask questions first. Does anyone know where I might start? I suspected a faulty 24v power supply when it had a load but after I replaced it the problem still exist. Any way to isolate where the problem might be?
Craig
