586,067 active members*
5,047 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Rotozip cutting .02 brass... what bit?
    Jul 2007
    35
    I'm a newbie that's using a CNC machine equipped with a rotozip as the spindle. I have had pretty good success cutting .02" brass sheet but I've run into problems where even at a very slow cutting rate the bit will get too hot and/or lose its cutting ability.
    What bit material would be best for cutting .02" brass (2D straight-through cuts) and what speed should I be running? Do I need to use some sort of coolant for the cuts?
    Thanks!
    Mar 2008
    31
    brass is one of the few freecutting material. No cutting fluid is needed as brass is a self lubricating material.
    Make sure the cutter u are using is sharp, and trail and error with feed rate etc. Shouldn't really have any problem with cutting it
    Feb 2008
    16
    Your "Rotozip" is probably running way to fast for brass. They were intended
    for things like dry wall and wood . If you slow it down it may not have enough
    torque to do the job.
    ...lew...
    Jul 2007
    35
    Can you tell me how fast it's supposed to go?
    Aug 2005
    578
    Bit
    Speed and feed are pretty much a matter of opinion. Tool manufacturers will give a standard that mostly work. Having said that it has been my experience that what Lew said is correct. I think the rotozip turns about 30,000 rpm and is way above what you should be cutting. and lowering to say 10,000 would help but the tool would bog down almost immediately because torque is reduced to 1/4 at that speed. Now there are a few tricks that work...I am assuming you are not using a wild alloy in brass(brass being an alloy anyway). Cutting with as few flutes as you can is best. turning at that speed the more relief in flute depth is premimum. So a single or 2 flute 1/2" bit will cut better than a 1/4 of the same bit material. and straight flutes will break up the chips better as spiral flute seem to curl the chips and is very undesirable in removal of debris. Due to the lead content in brass TIN coating doesnt seem to help with tool wear and in most cases hampers it. Since it is a free machining material no cutting fluid needs to be used. In most situations the use of high speed tool material and not carbide is used but at the speeds you are turning carbide might be a good option.
    Just my experience and opinion hope it helps.
    Bob
  1. Weld Brass to Brass
    By piratesover40 in forum Welding Brazing Soldering Sealing
    Last Post: 03-04-2008, 01:02 AM
  2. Rotozip RZ1 Parts
    By rweatherly in forum DIY CNC Router Table Machines
    Last Post: 02-21-2007, 08:24 PM
  3. Rotozip Dimensions??
    By mrbaseball in forum Commercial CNC Wood Routers
    Last Post: 11-15-2005, 02:35 AM
  4. Rotozip
    By Ursine in forum DIY CNC Router Table Machines
    Last Post: 09-05-2005, 11:05 PM
  5. ROTOZIP for any good?
    By TommyB in forum DIY CNC Router Table Machines
    Last Post: 03-03-2004, 12:37 AM
