586,296 active members*
4,194 visitors online*
Thread: Delta Tau
    Oct 2007
    179
    Delta Tau
    Has anybody used the Delta Tau PC to CNC retrofit system..?
    It looks like it will work with any type of servo/ amp set up..?
    Wondering how good the software and hardware is and how easy/hard it is to set up.
    Cheers John.
    May 2007
    10
    I installed a pmac pac on a nc punch press which went well. Should have used the card in a pc which is my new project retrofitting a 8 axis turbo to a 9 axis press brake. You can go online and get the programming manual which will give you an idea of what is involved. Unless you are using it in a vertical mill you will have to write your own operating software. The wireing is the easy part. Extremely powerful control which should be able to perform any task. As far as the servo amp, it can control anything on the market past and present. Incorporate a touch screen and you get rid of a lot of wireing while freeing up some imputs. A while back on E-bay someone was selling the Geo-brick which has the turbo 4-axis control and servo drives for $999.00. I don't think he got a bid, but has not relisted. He stated he had 6ea for sell ?? Maybe someone purchased all of them. Good luck and I hope you are like me and don't need much sleep.
    Mar 2007
    7
    I've used Delta Tau's Geo Brick drive/controller. It is very powerful and flexible, but not really for a beginners. I like their products, but have had very bad experience with reliability.
    Sep 2006
    10
    any1 here has used the open servo method for writting user defined servo algorithms? need some expert help. thank you
  1. Wye-delta, delta-wye configurations?
    By mackeym in forum Phase Converters
    Last Post: 07-06-2016, 10:26 PM
  2. Delta Tau Anyone
    By Al_The_Man in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-14-2010, 08:08 PM
  3. Delta-Wye (Wye-Delta)?
    By JasonCampbell in forum Servo Motors / Drives
    Last Post: 10-09-2007, 10:43 AM
  4. delta 40
    By rhurt in forum Tree
    Last Post: 03-25-2007, 04:33 AM
  5. delta tau
    By Jeremiah in forum Servo Motors / Drives
    Last Post: 06-23-2006, 01:41 AM
