586,119 active members*
3,697 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Will 230VDC work on a 200/220VDC Daewoo system?
    Mar 2008
    I have a question in regards to the power voltage input to our cnc machine. We just purchased a Daewoo (fanuc control) Puma from Canada. The required voltage input is stated as 200/220 volts & 50/60 hz (max of 175 amps).
    My question is: we have 480 vdc throughout our building. I have purchased a 480vdc to 240vdc transformer to input to the machine. I was hoping I'd be able to tap down to the 220vdc range but can only get down to 230vdc. Will 230vdc still be too high?
    I am used to seeing a +/- 15 vdc input acceptance.
    I am hoping this will work, but do not want to jeopardize the electrical system of an expensive machine. I could always get a custom made transformer to input 220vdc (though I'd have to uninstall the present transformer).
    Thanks.
    24221
    I have always found that Fanuc state 200vac supply +-10%,
    Go as high a voltage tap setting as you can on the primary taps, this will give you lower secondary.
    You should be able to get a 220v sec. or use a buck/boost transformer.
    Al.
    Albert E.
    Mar 2008
    thanks for the reply...
    to clarify the best method to go about this... it seems that while I still have the capability to switch out transformers (with a re-stocking fee of course), it would be best to use a 480V to 208V transformer.
    otherwise I'd need to get a buck-boost transformer (which seems like overhead).
    Unless, I can take a 480v to 240v transformer and get the 240v down to 220v...which seems unlikely, unless I could try tapping down the primary leads as suggested.
  1. Daewoo puma 8s
    By mroy0404 in forum Daewoo/Doosan
    Last Post: 06-14-2010, 07:58 AM
  2. New To Daewoo..... Any Others
    By rolinjunk in forum Daewoo/Doosan
    Last Post: 02-16-2009, 11:05 PM
  3. Daewoo 12L
    By toolendmill in forum Daewoo/Doosan
    Last Post: 03-08-2007, 01:09 AM
  4. Daewoo ACE-H80
    By Cncjunkie in forum Daewoo/Doosan
    Last Post: 03-13-2006, 01:55 PM
  5. DaeWoo Lynx 200 GL
    By fjd in forum Daewoo/Doosan
    Last Post: 10-30-2005, 03:43 AM
