Hi there,
How much dross is normal and how do you get rid of it ???
No matter what settings I use there is allways some dross on the underside of the parts and we use a chizle to remove it by hand, which is not fun, we use clean dry air on mild steel and I try to get the speed to a point where it just cuts the material by changing nozzle size, speed and amps. Is this the same for you or is there a solution, we don't have dual gas, hy-def. We use a TD151 with thc.
Interested to hear your stories.
Many Thanks,
Gordon
