586,094 active members*
4,054 visitors online*
    May 2006
    94
    pitted ball screw
    I just received a used ball screw bought off you-know-where. The screw (no name on it) is a 26" long 3/4" OD, 2 start, .5" travel per revolution. It seems to have no backlash, and turns very smoothly, except in two or three areas, a few inches apart from each other, where I can see minor pitted spots on the troughs of two or three of the threads, -- actually seems to be every other thread in these spots. It still turns easily through these areas, but i can feel a little resistance in these spots. This router is to be used for woodworking, though planned to do inlay, so reasonable precision will be required. Are these pitted areas apt to cause a problem? Can they be smoothed out somehow (with a round file, perhaps?) or would that make things worse? Thanks!
    Jan 2008
    124
    What ever you do, don't use a file! Try to smooth down any high spots or damage with a fine honing stone and oil. Atlernately wrap some very fine emory paper around the round file, use oil as a lubricant, and slowly and carefully try to blend it out. Clean the surface and test how it runs often as you smooth it.
  1. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 05:15 PM
  2. roller screw versus ball screw.
    By Paraprop in forum Linear and Rotary Motion
    Last Post: 04-15-2007, 10:21 AM
  3. Belt vrs. Ball Screw vrs. Lead Screw
    By stevesplanes in forum Linear and Rotary Motion
    Last Post: 01-09-2006, 06:23 PM
  4. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  5. acme screw to ball screw question
    By Billw in forum DIY CNC Router Table Machines
    Last Post: 07-18-2005, 06:10 AM
