Bottom of the T (upside down T) is 1/2" wide by 1/4" high, top is 1/4" x 1/4"
The small metric set from LMS will work, and there's a rather expensive set by dearmond that is meant for the Taig as well. Most people make their own flat nuts from 1/2" wide flat stock.
Originally Posted by
svarzaru
I've been looking around and I can't seem to find this info. Anyone knows (or can measure it)?
I'm asking because I have a taig on order and I'd like to purchase a t-slot clamp set (I know I could make some, but I'd rather work on making the parts I bough the taig to make ;-). There is a set on ebay for 3/8 slots with 5/16 studs, I'm pretty sure the nuts will not fit, and I might be willing to make those, but I'd like to make sure the 5/16 studs will fit.
Thank you.
Nick Carter
Largest resource on the web about Taig lathes and mills
www.cartertools.com
