586,104 active members*
3,310 visitors online*
Thread: Vacuum Pump
Results 1 to 6 of 6
    May 2007
    Vacuum Pump
    Hi, I had readed most of the threads regarding the vacuum table issue, i am looking for using something industrial, for continuos and multiple shape/material use. All comercial CNC routers packages advertise a FPZ or Becker, pump, and in most cases they are Regenerative type pumps, i had looked averywhere and seem that all the specs for this pumps are below the specs that i saw in previous threads in cnczone, so i might be out of focus about flowrate vs. vacuum, so i will plainly ask if a 18 HP Regenerative Pump with 100 inches of water and 795 CFM might be suitable for a 4x8 router table, which will be working mainly with mdf, and melamine, though a 3/4 sacrificial board. Thanks in advance to all of you who may share some of your knowledge with me.
    Jose Camilo
    Jul 2005
    12177
    Quote Originally Posted by jfcamilo View Post
    ..... with 100 inches of water....
    Jose Camilo
    Full vacuum is about 32 feet of water which is around 380 inches.
    100 inches of vacuum is not enough for direct vacuum hold down never mind using it with a spoil board.
    May 2007
    Quote Originally Posted by Geof View Post
    Geof,
    First of all thanks for your quick reply, i will like to know in your experience wich is a suitable vacuum pump (brand and/or model) that might be suited for my task?
    Thanks once again.
    Jose Camilo
    Jul 2005
    12177
    Sorry, cannot help with that information as I have never bought a vacuum pump.
    Jul 2006
    1256
    Jose,buonas diaz,
    Read this...http://www.shopbottools.com/vacuumholddown.htm
    Regen blowers are high CFM low pressure typically 5psi and suited for larger parts and pull through MDF spoil boards.Rotary vane are high vacuum low cfm and can get near 15PSI but leaks can be a problem and they are more expensive.If you are cutting cabinet parts I would go with the blower although our shop has a 25Hp Gast rotary vane.I think it cost $13 grand.
    Here is another link for a regen blower.http://www.grainger.com/Grainger/items/5F243
    I will check the specs on our pump and post later.
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    May 2007
    Igalla, thanks for your reply, i have been out of contact because of bussines, and in the meanwhile i bought a FPZ regen vacuum wich should be delivered to me soon, they claim that it makes the work, thanks to all that have replied.
    Jose Camilo
  1. Vacuum Pump From Compressor
    By Geof in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-10-2013, 05:05 AM
  2. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 05:30 PM
  3. My vacuum pump has gone wonky!
    By martinw in forum Mechanical Calculations/Engineering Design
    Last Post: 07-17-2007, 04:58 AM
  4. Pump for vacuum fixture
    By DAB_Design in forum DNC Problems and Solutions
    Last Post: 07-04-2004, 12:17 PM
  5. Where to get a vacuum pump
    By whiteriver in forum DIY CNC Router Table Machines
    Last Post: 05-11-2004, 04:47 PM
