586,069 active members*
3,946 visitors online*
IndustryArena Forum > CAM Software > Mastercam > MasterCam X2 rotary toolpaths, examples anyone?
Results 1 to 6 of 6
    Sep 2007
    32
    Hi guys!
    I have recently started planning a 4:th axis for my mill. I am thinking about simply adding a small lathe chuck to my table, so that the workpiece is parallel with the X axis.
    However my question is, how do i draw 4 axis toolpaths and geometry in Mastercam? I have tried different things but i don't understand how it is supposed to work and I can't find any "tutorials" or demos on the internet either.
    Does anyone have some simple example files that would get me started on learning this? For example a round stock piece in the chuck, drill a hole in it, rotate a couple of degrees, drill another hole and so on? I have tried drawing cylindrical solids and stuff like that but i don't know which toolpaths to use or anything.
    Thanks a lot for any help.
    Best regards
    MagooT
    Apr 2003
    3578
    There are not really any free stuff on 4th but there are books on it.
    but so fare what you are talking is simple Rotary substitution.
    Cadcam
    Sep 2007
    32
    Ok thanks for the reply.
    What book would you recommend?
    best regards
    MagooT
    Apr 2003
    3578
    Cadcam
    Sep 2007
    32
    Thanks. I shall see if i can get my hands on it somewhere around here.
    Meanwhile, i found som examples in the mastercam-folder, so i tried it out.
    But i can't get it to look like in the tutorial PDF, the toolpath around the cylinder gets split up into small movements, and the g-code gets huge. Why does this happen?
    Here is the mcx-file attached.
    Attached Files Attached Files
    Jul 2003
    263
    take a look at the sample files on MC's website. i picked up a lot from their samples
    If you can ENVISION it I can make it
  1. G-Code Examples
    By jhwatts in forum G-Code Programing
    Last Post: 05-01-2008, 04:54 PM
  2. Show some examples.
    By tjones in forum BobCad-Cam
    Last Post: 02-03-2008, 04:35 AM
  3. Can anyone post some examples, for when to ...
    By Stampede in forum BobCad-Cam
    Last Post: 10-29-2007, 09:05 PM
  4. further examples
    By amr_elsayed in forum CamWorks
    Last Post: 04-10-2007, 05:05 PM
  5. Need Examples... Plz help
    By Israa in forum G-Code Programing
    Last Post: 02-10-2007, 11:56 PM
