586,069 active members*
3,608 visitors online*
Page 1 of 2 12
Results 1 to 20 of 28
    Mar 2005
    63
    Cutting underwater with a plasma
    Has anyone any experience cutting underwater with plasma?
    Hoping to learn
    Dennis
    Jul 2005
    2415
    Can't be down with conventional plasma torches. You can cut ON Water (with water touching the back of the metal) and it cuts down dramatically on plasma smoke and dust and gives better cuts on stainless (reduced edge discoloration) and less warping on thin material. See the threads on constant level water tanks.
    Apr 2008
    44
    This guy here has a torchmate and cuts underwater don't think he does anything special http://www.l2manufacturing.com/cnc_plasma.html#
    Apr 2008
    40
    Just fire the torch before submerging is my guess
    Jan 2008
    2247
    Almost any plasma torch will fire and cut underwater...the question is...how long will the torch last! All of Hypertherm's industrial grade torches use high frequency start, which means there are no moving parts in the torch...and no low voltage switching power inside the torch assembly. These torches are designed for underwater cutting if it is desired.
    Most entry level air plasma torches, including all of Hypetherms Powermax torches...use a moving electrode inside the torch that creates a short circuit spark that ionizes the air and starts the arc. If these torches are used constantly in water it is possible that the moving parts inside the torch can become damaged or gunked up from the dirty water...rendering them inoperable. There is also a low voltage cap on safety switch mounted inside the torch mounting tube....this switch is not waterproof...and it likely will fail after repeated soakings. Other manufacturers including Thermal Dynamics, Miller and Lincoln use similar technology in their torches.
    Check with the manufacturer for compatibility with underwater cutting! If you are cutting with the water level below the top surface of the plate...you can likely use any torch.
    Jim Colt (Hypertherm)
    Mar 2005
    63
    Thank you all for yor feed back.
    I have a new Hypertherm 1000 and made my choice of machine because of the fine cut consumables and the great support here on this site. I'm thinking that I made a good choice.
    I'm hoping that I'm able to cut 14 ga #8 Stainless Steel finish with this torch with less dross and blueing than some of the other torches I've used in the past. It appears that under water cutting holds some good possibility for great results.
    I've yet to buy a cnc to put under this torch and after looking for some time now think so far the best cnc company (great support which is as important as the machine) and their cnc machine I've found is from Plasmaroute.com . Steve there has given me some remarkable help in solving my questions and has run some serious testing in my behalf. He definatly knows what he is doing with plasma.
    Now, hopefully I will get a bit more info from others that have cut this #8 SS and hopfully more a little help with the insights that experience yields.
    Still looking for the answers
    Dennis
    Jul 2004
    601
    Quote Originally Posted by nzben View Post
    If you look at the pic on the front page a little closer you will see the water just covers the plate. The air is blowing the water away from the torch, and isn't cutting under water.
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
    Apr 2008
    44
    If you look at the picture on the right hand side of the page at the top it looks to me like it's underwater.
    The other thing I was wondering is if you're cutting thin sheet at fast rates like over 1000ipm, will the warping still be an issue?
    Jan 2008
    2247
    Warping is usually eliminated with underwater cutting.
    Apr 2004
    44
    Dennis,
    check out Esabs Air Curtain (water muffler) P/N 22018
    Go to the ESAB web site and Plug: F-15-189-B into the search window to retrieve the article.
    This device mounts onto the business end of the torch and produces a curtain of air. Quote from article.
    "The device mounts onto the torch and produces a curtain of air. This allows the plasma arc to operate in a relatively dry zone, even though the torch has been submerged to reduce noise, fume, and are radiation".
    I think somthing similar could be rigged up for a Hypertherm torch, but you will need a fairly big compressor as it requires : 80 psi @ 1200cfh
    (5.5 bar @ 34 m3h) of clean, dry & oil-free shop air. The air flow could be triggered before the torch is submerged the torch head would never even get wet.
    Just a thought,
    Tig
    Jul 2004
    601
    Quote Originally Posted by Tig View Post
    Dennis,
    Just a thought,
    Tig
    That's 20 cfm! The air comp for that would cost as much as most people have in their tables.
    Jan 2008
    2247
    The Esab air curtain is designed for Esab's large industrial torches....the PT19xl, the PT600 and the PT15xl style torches. It performs a similar function to Hypertherm's air injected water muffler that was patented back in the 1980's for underwater cutting with a 340 Amp oxygen plasma...the Hypertherm HT400 and HT4001 systems.
    I am not aware of any of these devices that have been made to work with smaller air plasma systems....although the thought of using one is interesting. The biggest concern with most air plasma torches is that they have internal moving parts, and small microswitches internal to the torch that could be affected by water.
    Jim Colt
    Apr 2004
    44
    DSL PWR:
    Re:
    I think if you look around a bit you will find that almost any 7-10hp compressor will output 20cfm. My little Dewalt portable outputs 3.8cfm - 100psi at 2.7hp. Used it cost me $70.00
    Jim,
    Re:
    I don't think the inside of the torch would get wet: if dry air is used, and the air flow starts before the torch is submerged and keeps flowing independent of the shielding gas, ie, it is stopped only after the torch is lifted free of the water. Where is the contact with the water.
    This should be easy to setup with either a limit switch and relay wired up to a solenoid shutoff in the AirShield supply line, or perhaps using Mach3 to activate the shutoff relay.
    It might be worth a try.
    Tig
    Apr 2008
    5
    Cool
    I am the guy with the Torchmate water table! (www.L2manufacturing.com) This is my second design. The air turns on before the arc, so the water never gets to the electrode. I have been cutting with a submerged table for 4 years and never had a problem. Here are some pics of my first water table. The one on my website is my 2nd design.
    -Lee Adams
    Jan 2008
    2247
    A blowback electrode start (such as all Hypertherm, Thermal, Miller and Lincoln) can not have air flowing before the torch starts......they use the air flow to move the electrode, which ionizes the gas. Any high frequency start torch (older Hypertherm, Thermal, Miller , Lincoln and Esab) designs have preflow....and they will work submerged. High frequency start is used in almost all industral design torches today (read expensive, high duty cycle systems) and blowback start is used in almost all air plasma systems (read, affordable low duty cycle systems)
    It looks like you are using a Hypertherm blowback start torch...one of the Powermax units. If it continues to work submerged...thats great! I have heard of others operating them this way. Our engineers do not recomend this, however!
    Jim
    Apr 2008
    5
    Quote Originally Posted by jimcolt View Post
    Jim
    Thanks for info! Our systems have been working great for years. If we ever have any problems, I'll know who to ask!
    L2 Manufacturing, LLC.
    Apr 2008
    44
    Can the warping and heat zones on thin steels be reduced by cutting at high 1000ipm type speeds with a high current?
    Nice little jetboat by the way Lee
    Jul 2004
    601
    Cool, it's amazing what you can get away with when you don't know any better
    Quote Originally Posted by L2 Mfg View Post
    -Lee Adams
    Apr 2008
    5
    Quote Originally Posted by DSL PWR View Post
    I came on this forum just to share my experience, not to be insulted. I have been cutting this way for many years without a problem. I have worked for other plasma shops that have don't the same. It looks like there are a lot of know-it-alls on this forum. Therefore, If anyone wants to know more about how I plasma cut under water, you can email me though my website.
    Regards,
    Lee Adams
    Jul 2004
    601
    Lee,
    If you took my comment as an insult, I'm sorry, as it wasn't intended. You seem to be having good luck doing the underwater cutting, and I will be trying it on my table. How much water do you run over the plate?
Page 1 of 2 12
  1. Plasma cutting
    By jimini in forum Employment Opportunity
    Last Post: 03-06-2008, 04:28 AM
  2. Underwater Plasma ?
    By Barry_ward in forum Waterjet General Topics
    Last Post: 05-03-2007, 01:10 PM
  3. Looking for some Plasma Cutting
    By ArcadEd in forum Employment Opportunity
    Last Post: 05-09-2006, 02:26 PM
  4. The Great Underwater ROV Project of 2005!!
    By JavaDog in forum Hobby Discussion
    Last Post: 04-24-2006, 01:04 AM
  5. Plasma cutting mdf.
    By ynneb in forum Waterjet General Topics
    Last Post: 11-06-2004, 02:56 AM
