586,036 active members*
3,706 visitors online*
Results 1 to 1 of 1
    Mar 2004
    41
    stepper drive amplifier
    I've been brainstorming this idea for a while and i belive that i have a basic working circuit, this should take a standard bipolar motor drives output in and use it to drive a pair of logic level h bridges consisting of IRL 640 's . i know that i probably need pull ups and buffer and the like but i don't have any experience in practical design and so can not figure out what is needed if somone wit some more experience can look this over and help with this design i would be gratefull this design could be usefull in enhancing the current capacity of chips like the 3977 and others.
    Attached Files Attached Files
  1. Direct drive with stepper on rack and pinion.
    By jerryrigge in forum Linear and Rotary Motion
    Last Post: 10-10-2007, 03:21 AM
  2. Stepper As A Lathe Spindle Drive
    By mklb in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-18-2007, 04:47 AM
  3. Stepper drive question
    By Dman in forum DIY CNC Router Table Machines
    Last Post: 01-10-2005, 03:55 AM
  4. Need a low cost 4 amp, 48 volt, stepper drive
    By Mini Miller in forum Stepper Motors / Drives
    Last Post: 12-15-2004, 08:29 PM
  5. stepper drive help
    By bbrreid in forum CNC Machine Related Electronics
    Last Post: 08-28-2004, 07:45 PM
