586,058 active members*
3,826 visitors online*
Page 1 of 2 12
Results 1 to 20 of 26
    Nov 2007
    30
    Evaluate/critique my design
    I'm getting my ducks in a row to start building a 4'x8' gantry router table. Will you evaluate my design so far? I could use suggestions/help on motion, too.
    It's 4'x8'x7"
    Steel 1.5" x 3" x .125" frame with corner bracing and center supports.
    Skate bearing glides on Sched 40, .840" OD pipe.
    Gantry is 3/4" Baltic Birch construction.
    Y axis, pipe is bolted to metal 1.5"x 3" frame along sides
    X axis, wood torsion box w/top and bottom .840 OD pipe rails. skate bearings.
    Z axis, 2 .840" OD pipe rails with skate bearing glides.
    I'd like Y axis to be driven under the table by acme or belt. Acme for the other 2 axis's.
    How fast should I attempt to go? What will I need to get me there?
    I was inspired by the simplicity of www.buildyourcnc.com.
    My skills:
    Woodworking and basic metal working.
    Mig Welding
    Measuring accurately
    I have:
    10" Table saw
    12" Miter/chop saw
    Router
    Mig welder
    Grinder
    Drill press
    taps and dies
    lots of steel and wood
    I've attached several versions of the same drawing. (nuts)Give it to me straight(nuts)
    Attached Files Attached Files
    "I've got a long way to go and a short time to get there, We're gonna do what they say can't be done."
    You'll never be able to drive that gantry with one screw. It'll skew a lot. You can probably put a screw on each side, and still keep them under the table.
    If you plan on cutting 4x8 sheets, you'll need 9 or 10 ft screws. Most DIY machines that size use rack and pinion to avoid the long screws. If you want to use screws, you'll probably need to use 1" dia.
    How fast should you go? as fast as possible, or as fast as your budget permits. You're cutting speed will be limited by your router, but you can always take multiple passes as deep as the router will allow.
    I'd shoot for at least 200ipm, preferably more. Here's some info on choosing motors courtesy of GeckoDrive.
    Q.) Should I use servos or steppers in my machine?
    A.) If you are designing a machine and you get to motors, the first thing you should do is calculate the power you need. Never buy a motor (stepper or servo) first and then figure out if it will fit what you need.
    Motors are motors. They couple power to your mechanism and power is what makes things happen. The choice of a motor comes after you know what's needed.
    Power is velocity times force or torque times RPM. It doesn't matter if the motors are steppers, servos or a gerbil in a spinning squirrel cage at the start.
    To separate what motor need (neglect the gerbil), is the power your mechanism needs.
    Rule #1: If you need 100 Watts or less, use a step motor. If you need 200 Watts or more, you must use a servo. In between, either will do.
    So, how do you figure the power you need?
    Method 1: You have a plasma table, wood router or some other low work-load mechanism. You have a clear idea of how many IPM you want but you’re not sure of what force you want at that speed.
    Pick the weight of the heaviest item you are pushing around. If it weighs 40lbs, use 40lbs. multiply it by the IPM you want. Say that's 1,000 IPM. Divide the result by the magic number "531". The answer is 75.3 Watts so use a step motor.
    Eq: Watts = IPM * Lbs / 531
    Method 2: You have a Bridgeport CNC conversion you are doing. The machine has a 5 TPI screw and you need a work feed rate of 120 IPM. 120 IPM on a 5TPI screw 5 * 120 or 600 RPM.
    How about force? Not a clue? Use your machinist's experience on a manual machine. The hand crank is about 6" inches in diameter. How much force would you place on the hand crank before you figure you're not doing something right? I hear about 10 Lbs.
    10 Lbs is 160 oz, 160 oz on the end of a 3" moment-arm (6" diameter, remember?) is 480 in-oz (3 times 160) of torque on the leadscrew.
    The equation for rotary power is: Watts = in-oz * RPM / 1351
    For this example, Watts = 480 in-oz * 600 RPM / 1351 or 213 Watts.
    213 Watts is servo territory. You have to use a servo motor to get that, about a NEMA-34 one.
    Nov 2003
    244
    You might want to check out mechmate.com for a tried and proven table. can be built for under $4000.00 and you get a professional quality build with lots of support. This is my next build soon as I get the space.
    ...He who makes no mistakes makes nothing! ...
    Tom
    Nov 2007
    30
    Wouldn't a 1/2"-1 turn per inch work? critical rpm at 110" is 227 = 227 IPM.
    Is that correct?
    Quote Originally Posted by esm View Post
    Is that correct?
    I see about 190ipm with a fixed screw and rotating nut, and about 150ipm with double angular contact bearings at each end. Based on the charts at Nook.
    You're resolution will be a bit low, but should be adequate for what you plan on doing with it.
    Nov 2007
    30
    I didn't see the chart @ nook. I used their critical speed calculator. (see screen shot)
    I'll go back through through the forums and find the calculation for resolution and determine if it'll work.
    The machine needs to be at least as accurate as an highschooler with a hangover.
    May 2006
    138
    So about +/- 1/2" good? Great.
    To calculate the resolution you take 1 / [(steps per turn)*(turns per inch)] and you get inches per turn. Using your numbers you get 1 / (1 * 200), where 200 is full stepping the motor (most motors have 200 steps per revolution), which will give you 0.005". This seems good from what you've mentioned.
    Nov 2007
    30
    .005 will work just fine! 1/16" is good, 1/20" is great!
    Now about the racking ger21 mentioned. what about this? wyldesyde007's idea about the ol' drafting table cable, pulleys and spring. My old drafting table has fallen apart more times than I can count. It was my grandfather's, he got it in the Navy during WWII and although I've replaced several pieces and adjusted it from time to time, it's still square. Using that would eliminate complexity and cost.
    Aug 2007
    264
    esm,
    we're in the process of building a table of the same size. we've posted it on the diy router thread, might give you a few new ideas. not sure how to put the link on this post.
    Mike
    May 2006
    138
    It's an excellent way of eliminating racking, but don't absolutely depend on it. Build the router the best you can, and if there is racking after all is said and done apply that fix (or just use it to be sure).
    Nov 2007
    30
    Thanks Gir, I'll do that. Maybe I'll beef up the gantry sides a little more.
    Med-Pac, great machine. I've been scouring your pics and posts for ideas already
    Aug 2007
    264
    Thanks esm,
    We do have a few extra brackets left over. It took us a few trys to get it right, and cnc joe's help. If you could make these work on your table, I'd part with them pretty cheap. They're just collecting dust now anyways.
    Mike
    Nov 2007
    30
    Which brackets are you refering to?
    Aug 2007
    264
    Sorry about that, forgot to attach the pictures. Here they are, if you need measurements, I can email the dxf files. They were for the x and y axis steppers, some have the shaft welded in already.
    Mike
    Attached Thumbnails Attached Thumbnails plasma pics 3-24-08 008.jpg   plasma pics 3-24-08 007.jpg   plasma pics 3-24-08 009.jpg
    Nov 2007
    30
    Quote Originally Posted by Med-Pac View Post
    Thanks esm,
    Mike
    Thanks but I think I'm gonna go with 1/2"-1 acme under the center of the table. Beef up my gantry sides some more and incorporate the cable pulley anti-racking system. I'll drill mounting holes for the stepper directly into the frame perimeter.
    Mar 2006
    489
    I think your going to need alot of torque to drive that screw, and the router back driving the screw may be a huge problem unless you plan on having some sort of braking system.
    If you took a piece of 1/2" round bar and supported it on it's ends 8-10ft apart, it will deflect alot just sitting there by itself.
    I think Ger is right. At least 1", maybe larger. Bigger = more expensive. My advise would be to build a machine that has focus on performance rather than size. If you need a machine that big, get ready to pay big for the right stuff, but remember, if you do it wrong the first time, you can always just throw all the stuff away and buy the right stuff the second time...
    Nov 2007
    30
    Here's what I've come up with so far. (Courtesy of Mariss Freimanis)
    1) Power: 43 watts = 100lbs * 227IPM / 531
    2) Screw Torque: 510 in-oz = (8 * 100lbs) / (pi * 1 TPI)
    3) Picking a motor: No clue, must research more
    4) Resolution: .005"
    Quote Originally Posted by fatal-exception View Post
    Would you explain back driving/braking system?
    Thanks, keep it coming!
    Jul 2006
    1256
    I am not a good math guy,But I assume in Mariss formula I should add the weight of the screws and nuts.For example for a dual X drive with one screw a side,say 1"x10'. the total weight is 52 lbs for the drive .1000ipmx52lbs/531=97.9284 watts.That leaves 2.0716 Watts to move the gantry weight.I will not attempt to calculate the gantry weight suitable for stepper use,but guess it will be around 5lbs.Any dust or flies on the gantry will severely affect performance.
    Servo Country?
    2N'd thought.With R&P I do not have to add the weight of the rack,but must add the weight of 2 steppers and gearing.Seems there is no free lunch in CNC.For 4'x8'routers,looks like servos are in order.200ipm on a large router is like waiting for the kettle to boil.Back to the drawing board for me.
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Mar 2006
    489
    Quote Originally Posted by lgalla View Post
    Larry
    Totally agreed. even on my 24x24, it's sometimes like watching paint dry.
    esm - why are you limited to 227 rpm anyways? Is that all you can drive with your computer/driver setup? Back driving the screw could be described as the ability to make the screw (or nut) turn by applying a linear force, the opposite of what we want to do. The fewer teeth per inch, the easier it is to do this. Similarly, the fewer teeth per inch you have, the more torque you will require to accelerate the axis.
    i'd forget the 1/2" screws they are far too wimpy
    you may want to look at getting 3/4 " for the y and more for the x ,
    i used 3/4 screws on the x and y of my machine which is 5 feet across the x and 3 feet on the y , the screws are 10 start 2"/rev , it runs smooth using the gecko drivers and i get .001 resolution which in my opinion is plenty good for a wood router , the motors i use are 770oz steppers which are running 2/3 of the max voltage i can push through them , ive set the rapids to a moderate 500 ipm which keeps me well within the save zone (full torque) otherwise i can push to 1200-1500 which is unstable
    if you get some beefy screws with the correct resolution ,some geckos with 1200 oz motors and a heavy power supply i can t see why you can t easily get 1000 ipm ,unless of course your gantry is 500+ Lbs
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
Page 1 of 2 12
  1. New Machine Design book from Alexander Slocum (of Precision Machine Design)
    By toastydeath in forum Uncategorised MetalWorking Machines
    Last Post: 11-25-2009, 05:37 PM
  2. My CNC design
    By dex918 in forum Uncategorised MetalWorking Machines
    Last Post: 02-26-2008, 04:44 PM
  3. Finding Engineering Design Software For Automatic Machine Design
    By hellokitty in forum Uncategorised CAM Discussion
    Last Post: 01-06-2008, 07:39 AM
  4. DJs 80/20 design
    By djmartins in forum DIY CNC Router Table Machines
    Last Post: 12-24-2007, 03:17 PM
  5. When to evaluate new CAM software?
    By CJH in forum Uncategorised CAM Discussion
    Last Post: 07-14-2007, 11:17 PM
